Early Astradome Lifter Repair
Lost the astradome on my 60 Tradewind to high cross winds in the Texas panhandle last week. Found the dome replacement at VTS but realize now both lifters are damaged and missing top mount. Anyone repaired these or know of a source for replacement? Thanks
Attachment 383519 |
I don't know where you can get replacements, but there are pictures of the missing mounting hinge. You may be able to fab something based on the photos.
If you need dimensions let us know. |
Dimensions on the mounting hinge would be helpful. I have not taken the lifter apart yet but hopefully the top center can be drilled out, tapped, threaded and attached to a facsimile hinge. My research to this point says this is a common problem and inland rv's replacement is a poor copy. Thanks for the help! Richard
Skyhighrvparts.com has replacement Hehr vent LeDeux lifters, but expensive. Someone else had replicas in stock, but will try and remember. So many have replaced their Hehr vents with Maxxair and other brands, there should be some out there. Good luck
Dimensions are inches
Possible OEM replacement
Sent you a PM.
I see a pair of lifters listed in the classifieds.
65 Safari vent and lifters, Scott Graham. |
Try Inland RV. 1964 Safari, I got mine there a few years back. They fit great and work fine. They also have the Astrodome covers.
https://inlandrv.com/product/hehr-ro...tor-1951-1965/ -Dennis |
Just completed replacement of my Astrodome on my 62 safari. Got the dome from VTS and the lifters from Highskyrvparts but no mounting brackets. After $350.00 in parts and 3 days of labor I do have a working vent. Would I do it again? NO the AC is only 6ft. away. Wife says it looks nice so that’s all that matters.
Did you build new mounting brackets?
Must have missed it as I do not currently see this listing.
I just looked seems like it's still there.
In the classifieds, under parts, titled 65 Safari. |
I have a set for you
We are replacing the entire Astrodome in our 1964 Overlander. I will be selling our original lifters with brackets. Time line is early January when our new skylight from Maxim arrives. Are you interested? If so please send me a PM and we can discuss.
Lynn |
Haven’t had any luck getting an answer from Inland RV about replacement lifter. Anyone have luck finding them somewhere else?
