added water pump switch/indicator to IS 19
I have added a switch/indicator to the water pump at the sliding door entrance. There is no obvious indicator of the status or quick on/off for the water pump other than fiddling with the control panel, which can be a nuisance especially for those late night bath visits. The control panel operates as normal, the switch is wired in series at the water pump. The switch has 2 LEDs. No LED on indicates the pump is off at the panel. The bottom LED indicates the pump is on at the panel but the switch is off. Both LED indicates the pump and the switch are on.
I used this switch.https://www.amazon.com/WATER-PUMP-Et...s%2C186&sr=8-6 Thanks |
