Airstream Connect - Multi-Wan Load Balancing Router and????
Soon to receive '21 Atlas and seeking to optimize wifi. Consensus seems to be use Airstream Connect as installed because of integration with Airstream. Turn off Wifi as Lan. I want to add Verizon for duplicity. Seems to then call for a Dual-WAN load balancing router e.g. https://www.peplink.com/products/balance-20/
and also need a second modem for Verizon. Anyone else going down this rabbit research hole? |
Per Mike @Airstream (Great guy) for motorhomes ONLY - Router is NOT locked - Second Sim Card is available for use with different carrier |
