new cabinet latches
The 22Fb came with cheap plastic door/panel latches
1/2 started to fail ie they would open, but could not close them as the latch failed in the open position. I had to use a screw driver to ply the moving port open. Well, today i replaced them with roller catch from lee valley. part # 00w15.20 10 for only $6. they are high quality and will never fail as well, some panel door make a loud SLAm. i added thin pieces of felt on the edge of the door . all is quiet now |
Thx |
i also used VHB tape under the latches to keep them solid and stay in place
the hold is now stronger than the stock latches each latch cost less than $1 |
Brass bead latches.
Bob 🇺🇸 |
New cabinet latches
Waninae39, I had several original latches fail and have replaced them with these from Lee Valley and they are great, problem solved. Thanks for sharing.
