BoyouBiker - you're incorrect on this issue because you're not taking into account the overall system. Even after you yourself have experienced buckling in your tongue. The reason why any trailer, including lighter tongue weight trailers should not be dialing in greater than moderate 50% FALR, is because the tongues on those trailers are always sized for their expected loads. They are part of the system and perhaps the weak link. You can't just consider the tow vehicle. To be applying greater than 50%, particularly when paired with a tow vehicle that is larger, longer, and stiffly sprung as HD trucks are is ridiculous if you can understand the torsional forces involved. The reasons for 50% FALR on a large heavy trailer is the same for 50% on a lighter trailer. A lighter trailer did not suddenly have a tongue structure sized up because you're towing with an HD truck. Nor did it get sized up enough for greater than expected 50% FALR. It's no wonder tongues get stressed and structures buckle. |
Idk, pteck Profxd is making an argument about WD from the tow vehicle perspective and my response was in answer to that. I agree that use of stiff WD bars with high spring rates are hard on trailers, but I wonder about the tradeoff between setting optimal WD and sway control tension vs. reduced tension as you suggest.
I wonder about the damage mechanism in particular. As an example, my truck is a 4x4 and has significant rear spring travel. It drops 3.25 inches when I add trailer and the gear. It has 3 more inches to the bottoming stops, though the final spring kicks in at about 1.5 inches. The Blue Ox at 50% FALR was adding about 150 lb of net upward force on the ball, at 100% it was about 300 lb. The truck springs are supporting 900 and 750 respectively. When the combination hits a bump, the chassis and trailer frame is pushed upward and jars the trailer body and skins which resist the upward movement. So the question is which is harder on the trailer skin? Is the extra 150 supported by WD or the 150 supported by the truck? How does this change when considering WD stiffness? I will pause for comments as I wonder if anyone wants to help out. |
How long did it take to have the work done at JC? |
