-   -   Check my setup. F250 & GT25' FBT Equalizer Hitch (https://www.airforums.com/forums/f238/check-my-setup-f250-and-gt25-fbt-equalizer-hitch-215780.html)
TowmaterATX 10-19-2020 03:50 PM
Originally Posted by Spaggs (Post 2423485)
Since you mentioned tire pressures, I’ll add my two cents. To properly determine pressure, you should measure tire temps. The measurements should be taken at the inside, center and outside of the tread (where rubber meets the road) for each tire of your tow vehicle and trailer. The temps, ideally should be the same across the tire. You can use any kind of gauge, but the quicker read-out the better. This won’t give you the best gas mileage, but it will give you the best tire wear and most stable platform. If you find higher temps on one side or another, an alignment is needed. If the center temp is higher than the sides, lower the pressure. Similarly, if temps are lower in the center, increase the pressure.
Good looking setup!
Thanks for the pointer. I've got one of those infra handheld meters. So next time I'm towing I think I'll measure just like you say. Would be cool if FLIR cameras got cheap enough you could mount them in the wheel well and watch them like we do our backup cameras.
TowmaterATX 10-19-2020 04:00 PM
For those saying the bars are too stiff. I used this page: https://www.equalizerhitch.com/find-your-hitch-size and used 7900 gross weight on the trailer and 940 lbs for the tonuge weight and 250 for payload (camping stuff in the bed etc). It recommends the 12k/1.2k setup. Is it just that that is too much for the way the Airstreams are built? Unfortunately the 1000# bars are not compatible with my head so I'd have to replace most of the hitch to change down to the 1000#.
Thoughts?
Antique Pedaler 10-19-2020 04:04 PM
I also have the 2500 pu and 25’ trailer. He doesn’t post anymore, but Andy at Inland RV in CA and who was a trailer accident investigator in an earlier life found that there was a correlation between pickups and trailer hitch strengths. He found that as you went up from 1500 to 2500 to 3500s the strength of the hitch should be decreased from 12000 to 10000 to even 6000 for a 25’ Airstream. I had a 6000 Equal I zer on a 23’ Airstream so I tried it on the 25’ trailer. Long story short, the 6000 Equal I zer is still on my 25’ Airstream 11 years and thousands of miles later.
ROBERT CROSS 10-19-2020 04:13 PM
Disclaimer....I noe nothing.
You need 1000lb,(or less). It's not the tongue weight, it's how much of that weight do you need to move.
BTW...you do not know the actual TW.
TW is measured unhitched on a scale.
Receiver weight is measured on the CAT hitched.
Our TW is 1200lb.
860lb receiver wt with WD set
560 to the FA
160 to the AS
720 moved with 1000lb WD bars.
BTW...the link you provided won't even provide a recommendation for anything over an 800lb TW on a 7300 GVW with a 1000lb payload
TowmaterATX 10-19-2020 04:43 PM
Our TW is 1200lb.
560 to the FA
160 to the AS
Hi Bob,
I'm a bit confused. If I weight the truck without the trailer and then with it hooked up but not using weight distribution wouldn't the difference on the trucks axles be the tongue weight? Gross weight of the truck without the trailer hitched was 7700# and when I hitched it both axles on the truck weighed 940# less. Will I see something different if I weigh without the truck?
Oh, and the payload on that website calc is for the weight behind the axle. (not including the hitch weight)
Life is a Highway 10-26-2020 12:03 AM
The Dimples
Originally Posted by BayouBiker (Post 2423274)
Looks and sounds very well set-up. Ball is nice and close to the bumper. Have you thought about tire pressures? They can make a big difference also. Loaded our 25' FBT has a tongue weight of 1020-1120 depending on grey and black tank levels. Ford's FALR guidance applies near the upper towing limits so you have some room to fine tune based on actual road experience, particularly if you run the rear tires with a bit more pressure.
Be aware though many/most modern trailers with front storage compartments are experiencing dimpling and creasing of the lower outer sheet at the lower corners of the storage compartment. Airstream is aware, perhaps they have shored up the structure for the 21 model year. Large trucks, stiff WD bars with high tension and high trailer tire pressures seem to contribute. I have very small dimpling which has not gotten worse since I went to lower trailer tire pressure and a more forgiving WD set-up. Would love to hear your experience as you use the trailer.
Yes happened to our trailer and ruined a summer vacation while it was repaired. My 250 with equalizer only needs the 10,000 bars. Been at Jackson three times this year, Every time I look at a ft storage trailer I see the dimples. Most people are NOT happy when you show them, some are grateful to get it fixed. I just saw a new 27 GT dimples and cracked bad! They are VERY busy fixing this. I would not buy a trailer with a ft locker again.
Jasper Ash 10-26-2020 10:14 AM
You had me satisfied at “F-250”.
I can also confirm that stiff bars on a big truck can cause a stress crease below the front storage hatch. Definitely something to keep an eye on with that 25FB. Our trailer was delivered to us with this stress crease. We thought our new Airstream was delivered on a flatbed but turns out it was hitched up and towed down - likely by a big strong truck and heavy duty bars.
We tow our 27FB with a Tundra and 14,000 lb bars. I wanted to drop down to 12,000 lb or 10,000 lb but Equalizer informed us that both the 12,000 lb and 14,000 lb bars are of the same size and strength so we left it as-is. The stress crease has not gotten worse over time.
TowmaterATX 10-26-2020 12:46 PM
Can one of you please post a picture of the crease so I know what to look for. Is this for the front storage area near the battery box? or the front curb side locker?
Thanks!
BayouBiker 10-26-2020 01:43 PM
Here are my little dimples. Initially, there was no deformation in this area.
Attachment 381892
Attachment 381893
It is the front compartment behind the battery box.
TowmaterATX 10-26-2020 01:46 PM
Thanks Brian. I haven't noticed anything like that yet, but I only towed it about 19 miles with the bars connected. I'll take some pictures now so I can compare if anything does happen there. Of course it will be a while before I take it anywhere. It's all torn apart for the electrical upgrade right now. :)
Jasper Ash 10-27-2020 08:42 AM
Here’s what my stress crease looks like. It’s only on one side of the front hatch. Again, it came like this when delivered new, and had not gotten worse with my 14,000 lb bars on a Tundra. But I feel I’m risking a crack forming so I’ll eventually drop down to 12,000 or 10,000 lb bars.
Jasper Ash 10-27-2020 08:45 AM
What did Airstream do to repair? Replace the front panel or just reinforce the area? Airstream is aware of our issue but I’m hesitant to let a local dealer touch it in fear that removing a panel will make things worse or cause fitment issues elsewhere. For the most part I’ve come to terms with the little stress crease and I can live with it if it doesn’t get any worse. But I would love to know how others have handled it.
Agreed. Never a front storage hatch again. I don’t even care to use it, I have no problem lifting the bed to access the area. I would love to take it Jackson Center and have the front panel replace with a solid panel with no storage door.
KK4YZ 10-27-2020 09:15 AM
Attachment 381892
Attachment 381893
Brian,
Are you referring to the separation between the skin and the belt line in the lower left?
I have that on my 28 RBT (no front hatch). 8000 miles on the trailer.
I have an equalizer with 1000 lb bars. F350 TV.
THANKS,
bird_dg 10-27-2020 12:53 PM
I found the ‘dimples’ as well on our 2018 27 FC front twin and almost every other front twin trailer I looked at. I kept having dinette cushions and pillows on the floor after traveling and started looking closer. My TV is also 3/4 ton PU with an Equalizer & 1000# bars, set up by the Airstream dealer on purchase. As an experiment I towed without the bars and the inside of the trailer faired much better, no tossed pillows and messed up cabinets and little if any change noticed from inside the truck. I have reduced the number of washers on the hitch from 6 to 4 to lessen the tension on the L brackets and will test this setup on the next trip. My guess is that on the smaller Airstreams being towed with 3/4 or 1 ton trucks, less WD or bar tension is probably easier on the trailer.
MimiandRandy 10-29-2020 05:07 PM
Drop shank ground clearance
Originally Posted by TowmaterATX (Post 2423236)
I spent today setting up my hitch and running to the CAT scales to finish the fine tuning. Would love to get some feedback on where I settled.
Truck is a 2020 F250 Plat.
Trailer is a 2021 GT 25 FBT
Hitch is 12k Equalizer
Final setup was 5 washers and L bracket attached through the 2 middle holes.
Truck only - Front 4280 Rear 3420 Gross 7700
Truck no w dist - Front 3900 Rear 4740 Trailer 5400 Gross 14040
Final tuned setup - Front 4100 Rear 4380 Trailer 5580 Gross 14060
I took a picture from a distance and everything looks pretty level as well (attached).
The front is 1/4 to 1/2 inch lower than the back when parked on what I believe was level ground.
Looks like I lost 380lbs off the front and with the hitch I put 200 back on. That's about 52% put back. The manual said shoot for 50% to slightly over so I figured that's good.
Looks like my tongue weight is 940lbs. It has full propane, but the trailer is still pretty empty. Plan to rerun my weights once I get it loaded and add water etc. Since that is so high, I'm glad I chose to go with the 12k equalizer head and bars.
Any suggestions on further adjustments welcome!
Thanks!
Question: I just set-up my F250 with an 11” drop shank. With my rig leveled and Equalizer WD set-up my shank only has a ground clearance of 6”. Equalizer tells me that is the minimum acceptable height. I’m curious: what is the ground clearance beneath your drop shank?
JonDNC 10-29-2020 05:31 PM
Not apples to apples
F350 2019 FX4. 12.5” from bottom of drop shank. Running a blue ox hitch.
But my airstream has a lift kit so without that would have been 9 or 9.5 inches
BayouBiker 10-29-2020 08:57 PM
the spare tire bracket is at 7.5. My shank is at 6 also. I'd rather have the shank hit than the tire bracket. You?
TowmaterATX 10-29-2020 10:08 PM
I will measure for sure next time it's rigged, but I would guess I'm in the range of 8-9 inches off the ground. The shank is maybe 12" from the top to bottom. The truck drops a couple inches when loaded. So maybe 14" down, but it starts about 22.5" from the top of the receiver tube. So that leaves it around 8". This is all from memory and a guess. I'll measure next time I have it hooked up.
Warpath 10-30-2020 07:53 AM
I have a 2021 25fbt. I also have 12,000# bars. I called and talked to equalizer about our pin weight and and how much I put in the back of the truck. The rep said that 10,000# bars would be overloaded and I needed the 12,000lb bars. He said because we were so close on pin weight plus anything stored behind the wheels when towing in the bed of the truck affect the bars ratings.
olgoat 11-03-2020 08:41 PM
I also found the same crease after delivery. In the photos from the dealer, the crease was already there. JC replaced the panel and no issues since. TV is a 2019 F-250 with a 12k Reese Steadiflex WD system
