Running Lights
Is there normally a gasket that sits between the plastic body of a running light and the exterior aluminum skin of the trailer? How is this junction normally made water tight. I've discovered a small leak and suspect that this might be the source. Thanks in advance!
Cheers! |
Most do have gaskets. At least the factory applied ones. I have used several things over the years to keep water out, from clear silicone, to butyl rubber, to gasket material, to Silkaflex. Some things seemed to work better for me, such as the butyl rubber, and Silkaflex.
Typically you can buy it (butyl rubber) in a tube and apply it just as you would caulk.
You can also get butyl tape. It's the roll of stuff that you use around and under roof vents for water-proofing. It cuts with a razor knife and has a bit of adhesive quality......would make for great gaskets!
