-   -   External Propane Tank (https://www.airforums.com/forums/f287/external-propane-tank-215062.html)
trepine 10-01-2020 08:10 AM
We are staying over the winter in a cooler climate. We wanted to get a large 100 lb propane tank. What is the easiest way to connect this tank to the airstream. What is the best way to connect it.
This is a 2019 classic 33
lsbrodsky 10-01-2020 08:28 AM
I am sure there are others who have done this, but here is what I would do. I would buy a longer hose with the right the connections, disconnect one pigtail from your regulator and run the tank end out the bottom of the propane tank shield, connect the smaller end to your regulator.
Larry
