-   Lights - Interior & Exterior (https://www.airforums.com/forums/f447/)
-   -   Blinking side round white porch light. (https://www.airforums.com/forums/f447/blinking-side-round-white-porch-light-214750.html)
Cordovac 09-24-2020 09:25 AM
1968 airstream caravel 17í. The round white light (porch) by the entrance is blinking. Is it supposed to? Anyone had this issue? Never really used it before. Itís not flickering, but a strong steady blink while Iím plugged in at home charging the batteries. Any advice? Thanks.
gdesign 10-25-2020 03:44 AM
Bulb could be going out, or switch issues.
Also connection at the bulb can be an issue. Get a $7-$10 tube of Dielectric Grease and coating the metal in the lights will help protect the metal parts and increase the connectivity to keep the lights working.
Bubba L 10-25-2020 07:11 AM
The hot on your Scare Light is normally daisy-chained with all your running lights. Theyíre individually grounded to the aluminum shell At each fixture. You can take the lens off and see if the ground wire is visible. If not, you may have to take the can out to get to the wire. Make sure the wire has good, tight contact ground connection and the bulb socket is free of corrosion. As stated, Dielectric Grease is a good thing. Good luck
