-   -   Cracked Window Rock Guard (https://www.airforums.com/forums/f454/cracked-window-rock-guard-214420.html)
KelloggKid 09-16-2020 05:14 PM
My curbside window rock guard took a hit from a rock thrown by a passing car. There is a very small pin head sized chip on the outside. When viewed from the inside however, there are 3-4 cracks emanating outward. These cracks do not go all the way through to the outside.
I've searched and found multiple threads on the topic which contain conflicting suggestions for a cure. I have two questions:
1) If I do nothing are these cracks likely to grow? Previous postings are split about 50/50 on this question.
2) If they are likely to grow I will drill small stop holes at the end of each crack and apply a solvent to "weld" the polycarbonate. The question is what solvent would be appropriate? Some previous postings suggest acetone and other postings say that will cause the polycarbonate to shatter.
I don't have $600 laying around so replacing the panel is not an option.
Thanks for your thoughtful responses.....
Leilanisteve 09-16-2020 05:32 PM
Following. Iíve one going too.
SpinWhite 09-16-2020 05:40 PM
I drilled the small holes then applied supper glue.
KelloggKid 09-17-2020 04:21 PM
Does anyone see a problem with using this stuff?
https://www.amazon.com/Weldon-Applic...0377618&sr=8-2
Halford1 09-17-2020 04:57 PM
possible to do Rock Chip repair at any auto Glass shops?
dznf0g 09-17-2020 05:17 PM
First off, unless things have changed, they are not polycarbonate, but rather plexiglass. A long time ago, there was a discussion about replacing the smoked material only.....by buying sheets locally.
The debate was whether one could use polycarbonate, or would the bend result in breakage?? A large oven would help, but who has one big enough??
My star cracks have never run, and some are 7 or 8 years old. One of these days, I will procure sheets of plexi and disassemble the frames and replace. Conventional wisdom was that plexi can make the bend with some prudent heat gun help.
