-   Refrigerators (https://www.airforums.com/forums/f425/)
-   -   Dometic Fridge Pilot? (https://www.airforums.com/forums/f425/dometic-fridge-pilot-212602.html)
Mopperator 08-10-2020 12:40 PM
My 1963 propane only dometic M50 a fridge Burner lights and stays lit. I get a flame at the base of my burner barrel assembly that jumps around a bit. Is this the pilot? Sometimes it goes out but gets re lit by the blue burner flame. I just donít know if itís working correctly as I havenít used it in 15 years. Thanks in advance for your knowledge!
rmkrum 08-10-2020 03:41 PM
Sounds more like a gas leak burning in the wrong place. Iíd have a gas refrigerator tech look at it.
Mopperator 08-10-2020 06:15 PM
So I just figured where the pilot lights and learned that it only stays lit when I hold down the button.
rmkrum 08-10-2020 06:27 PM
That points to a bad thermocouple that might have a bad electrical connection to the gas valve or it has actually failed...
