-   Windows, Doors, Locks & Vents (https://www.airforums.com/forums/f164/)
-   -   What kind of glue should I use to put in a small vista window? (https://www.airforums.com/forums/f164/what-kind-of-glue-should-i-use-to-put-in-a-small-vista-window-212451.html)
megan1968 08-07-2020 04:50 PM
Hello,
I've been working towards improving the windows on my 1968 Airstream Ambassador. I have successfully put in a Corning window that was missing when the trailer was purchased.
Although, I noticed one of the small vista windows in the front of the trailer was replaced by the previous owner with plexi glass. So, I went and got some car glass custom cut. Luckly this window is flat so I saved a lot of money not having to purchase curved glass.
My issue is that I don't want to use silcone as a glue to install the glass. So I'm wondering what adhesive would be compatible with glass and aluminum, but also safe to use on the Airstream?
Thank you for the help!
-Megan
mbubbaca 08-07-2020 06:24 PM
SEALANTS: SUMMARY :
Taken from previous Thread on sealants. Copy and paste put it in a document.Print and SAVE
NO SILICONE:
For wheel wells/underbody:
Vulkem 116
Trempro 635 Grey
Sikaflex 221 Black (use Eternabond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams, seals and bonds. Use Eternabond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
EternaBondŽ AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Lexel™ Clear
Windows/Trim/Rubrail/Exterior Lights:
Sikaflex 221 Grey (seals and bonds. Use Eternabond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes, prep and clean-up use cosmoline remover)
Trempro 635 Grey
LoctiteŽ PLŽ S40 Polyurethane Window Door and Siding Sealant
Lexel™ Clear
Small seams (between aluminum panels):
Acryl-R (available in cans from Airstream store. Use applicator or disposable syringes to apply)
Aluminum Pigmented Gutterseal
Rivet sealer:
Captain Tolley's Creeping Crack Cure
Parbond Gray or Clear (small hand tubes), also good for small gaps (<1/8”) such as top of belt line rub rail, door/window frames, etc
