-   -   No water to toilet or bathroom sink (https://www.airforums.com/forums/f163/no-water-to-toilet-or-bathroom-sink-212412.html)
Buck1948 08-06-2020 04:25 PM
We have water to the shower and kitchen sink, but none in the toilet or bathroom sink. That's using either the tank water or city water. We tried both and still no water in the toilet or bathroom sink.
BayouBiker 08-06-2020 04:41 PM
There are shut-off valves to the sink and toilet. Perhaps they were closed for winterizing.....
Buck1948 08-07-2020 08:19 AM
We are the original owners. It's never been wintered. Also, we have not turned the valves under the sink or toilet. When we turn on the kitchen sink water sputters then runs. The shower works normally. Haven't seen any kinked hoses or any other problems by looking under the sinks. Thanks
BayouBiker 08-07-2020 08:51 AM
That's very odd. The hot and cold water is independent once it leaves the water heater area, but there is a common cold over to the side of the trailer that seems to be not working and it also feeds the water heater. Can you confirm you have both hot and cold to the shower and galley?
Pdunbar 08-07-2020 09:16 AM
Bathroom sink
Unscrew the cap on the tap..it gets filled with crytal junk over the winter and clean it out
rowiebowie 08-07-2020 09:17 AM
Just spit-balling here, but my Avenue class B lost water flow to the toilet and the cold bath faucet. Had some mineral gunk in the cold water side. The washers had screens at the connections and were almost completely blocked. But it didn't happen overnight, but fairly quickly. And always had hot water at the bath faucet.
bibbs 08-07-2020 12:12 PM
Had the same problem with the toilet in my 75’ I had to replace the valve, it was mineral deposits. You could soak the parts in vinegar. If that is the case.
Buck1948 08-08-2020 12:51 PM
I'd like to thank everyone that replied with helpful advice.
The problem with the sink was a clogged filter which I cleaned. Problem solved! The toilet - I removed the toilet and cleaned all the calcium that was blocking the water flow. Re-installed the toilet and it works great! Thank so much:-))
