-   -   Eu2000i muffler cleaning ideas? (https://www.airforums.com/forums/f37/eu2000i-muffler-cleaning-ideas-211798.html)
groundhogy 07-25-2020 09:20 PM
Its $135 for a new one.
Mine is completely blocked. If you blow on it, nothing goes through.
Any ideas?
What is the internal structure of these things?
Is it just a cavity or is there like a zig-zag path?
dznf0g 07-25-2020 09:29 PM
I dont have my manual with me, but I recall there is a spark arrestor which can be removed and cleaned.
azflycaster 07-25-2020 10:04 PM
Instructions here:
https://www.ereplacementparts.com/re...Generator.html
groundhogy 07-25-2020 10:34 PM
Yes I can get to the screen/arrestor.
But the muffler is blocked inside somewhere, so it’s going to need to be soaked/sprayed/poked.
OTRA15 07-26-2020 05:17 AM
For every one's information, this earlier thread is the lead-up: https://www.airforums.com/forums/f37...es-211717.html
In view of your total labor hours on this project, is the $135 cost of a new muffler really so prohibitive, if it gets the gen working correctly again?
:blink:
ROBERT CROSS 07-26-2020 07:13 AM
It dissolve's rust...worth a try.
dznf0g 07-26-2020 08:14 AM
Do you have any estimate of the hours on your genny?
groundhogy 08-03-2020 11:47 PM
Original Poster:
I tried brake cleaner.. not so effective
Carb cleaner.. better than brake cleaner it seemed.
This carbon seems resistant to cleaning.
Then I fired up my grill and tossed in the muffler. Turned it over a few times. I think the hotter you get, the more carbon gets burned off. Dont think my grill was extremely hot. When i was done, i tapped the muffler all over.
Also picked up some rubber corks at the hardware store. This so i could fill the muffler with carb cleaner. But also you can drill a little hole through the cork and put the little red straw through it. Then you can blow canned air through it if you don’t have a compressor available.
The cork/can thing also allowed me to bust through the initial full blockage.
Muffler pretty clean now.
CarterKraft 08-07-2020 07:08 PM
too slow
Gas grill was my suggestion.
On dirt bikes we use propane torch to clean spark arrestors, that works really well.
groundhogy 08-07-2020 11:14 PM
Ooops. Sorry for not saying thanks for the grill suggestion! It worked.
OTRA15 08-08-2020 04:10 AM
Thanks for the update . . . wondering if the spark arrestor still works as designed after all of this, like a new one would?
:blink:
Maybe fire up the genny at night, and check for sparks?
dznf0g 08-08-2020 05:07 AM
That's what the Honda service manual says to do.
Bill M. 08-08-2020 06:50 AM
Keep at it. If you could develop a solvent for burned carbon you will make a fortune.
