-   Refrigerators (https://www.airforums.com/forums/f425/)
-   -   Broken plastic hinge on Norcold Fridge (https://www.airforums.com/forums/f425/broken-plastic-hinge-on-norcold-fridge-210402.html)
treegrower 06-28-2020 11:40 AM
The lower door hinge on my Norcold 7 cf fridge has broken off. It is cheaply made of plastic. i can try to epoxy it back on but the plastic construction is inherently weak. Have tried Norcold but no response.
Does anyone have a suggestion for permanent repair?
wondering if I could attach an aluminum strip to bottom of door and drill hole in it to aline with hinge pin. Could that be screwed into door bottom, not sure if door has a metal frame or all plastic
Thanks for help
