1979 Airstream Tradewind
Im selling my 1979 Airstream Tradewinds that has been fully restored, just needs the finishing touches.
New brakes, brake lines, tires, electrical, plumbing throughout entire trailer. New freshwater and grey water tanks and heating pads to prevent freezing. New subfloor and new insulation throughout trailer. Pink insulation under floor and spray foam insulation on walls of trailer. New electric jack and 7 pin connector. Rodent proof with new patching throughout. New thermostat for brand new A/C and new water heater. New regulator and pigtails. Four new leveling jacks, and sensors for fresh and grey water tanks. New 110v and 12v wiring throughout. Three new batteries and wiring for off grid applications. New inverter and converter. 3 120watt flexible solar panels. New water pump and new copper propane branch lines for new hot water heater, new furnace, new refrigerator, and new stove. All appliances are Dometic. 12 new overhead recessed 12V LED lights. 6 new 12V reading lights, 9 new outlets, and switches throughout. A new roll of aluminum, .032 6061T6 sheet, 48 X 144. New PVL flooring throughout. New sway bars. All receipts, brochures, schematics, work orders, you name it available. Most work done by Vintage Trailer in Denver CO. This is a fully finished airstream that just needs finishing touches. Make it your dream Airstream without going through the renovation headaches. Happy to answer any questions or show the trailer if you are in the area. View this ad at Airstream Classifieds - 1979 Airstream Tradewind https://www.airstreamclassifieds.com...f78afd77f0.jpg https://www.airstreamclassifieds.com...4185c4da03.jpg https://www.airstreamclassifieds.com...b7c5898c2e.jpg https://www.airstreamclassifieds.com...beef1cd211.jpg https://www.airstreamclassifieds.com...0a19ca9026.jpg https://www.airstreamclassifieds.com...2478b4f056.jpg https://www.airstreamclassifieds.com...4d544e2bab.jpg https://www.airstreamclassifieds.com...95ea5c28dd.jpg https://www.airstreamclassifieds.com...11632a63a3.jpg https://www.airstreamclassifieds.com...d6cc1c3f77.jpg |
Fully finished doesn’t quite equate with the pictures. Does it not need the entire interior replaced? I am interested, if it only needs some finishing touches.
Is this trailer still available?
Has any work been done on the axles, frame or subfloor? Does it have any leaks? Do you have pictures of the finished trailer? |
