-   -   2016 Lounge EXT Lithium Journey (https://www.airforums.com/forums/f240/2016-lounge-ext-lithium-journey-207109.html)
Chris Blank 04-05-2020 10:00 AM
Hello all,
I think this is my first post, but I have been reading a lot. To sum it up, we bought the van at the beginning of Feb and just now finishing up my mods at the beginning of April.
Goals:
- Ditch the lead acid, add capacity
- Run AC on battery to leave the dogs inside while we go to dinner or are away for a couple hours at a time.
- Run the microwave while underway
- Warmer weather also required using the rooftop AC while underway
- Make LB_3 and Lew proud with the install
- Conserve interior space
These goals led to some sub-goals
- Ditch the obnoxious generator
- Need some way of charging
- Solar is not an option because of the lack of roof real estate
- Install Nation's dual alternator
- Ditch the terrible underslung battery brackets
Basics of the system:
Several Valence 138ah Lithium Iron Phosphate batteries
Victron 3000w inverter/charger
Victron BMV712 monitor
VenusOS/Raspberry Pi Victron monitoring and control
Removed Magnum inverter/charger, generator, and stock fuse/breaker box
I was able to squeeze the Victron under the left side seat where the original fuse/breaker box sat. I fabb'ed up a new push button AC circuit breaker panel with a 12 place DC fuse holder. All the cabling sits above the wheelwell where the Magnum used to sit.
I tried to keep the batteries in the same location, underslung, but I have too many concerns with the integrity of the sheetmetal mounting the factory used. I may revisit this later, but for now, I, sadly, placed 2x batteries under the right side of the sofa. That space was underutilized anyway. I can still fit my tote of power cable and water hose in the same space. I would like to add more batteries, but that will come later. Perhaps I will build a rack that can install where the generator lived. In the meantime, keeping the batteries inside will help prevent charging them frozen until I can figure out a better solution.
I installed the Nation's 3 belt alternator system, but unfortunately, it does not seem to be outputting enough power to keep up with the 123 amps required for the rooftop AC Compressor. It is able to supply 71 amps and 51.x comes from the battery. Unacceptable for a 280amp rated alternator. I am currently troubleshooting this issue. I have 0/1 cable from the + of the alternator going back to the Pos bus bar and double 0/1 going from the bus to the battery and to the inverter. Also upgraded a 1 awg ground strap from the alternator case to the frame (made no difference before vs after).
Rewired the fridge and electric water heater to operate off AC-2 pass through of the inverter so that it is only powered with shore power
Removed the solenoid so now the house and chassis systems are completely separate.
Initially, I tried to just relocate the fuse/breaker box above, but with the seat installed, this proved pointless.
The flex solar panel is still there, but not hooked up to anything. I despise the Atkinson charge controller with its 4 mins on and 4 mins off routine. The voltage isn't high enough for the lithiums, anyway. I actually ordered a Victron charge controller, but returned it since I should be able to make more power in an hour with the alternator than I ever could for several days with solar.
I was able to reuse the comm cables (RJ45 and RJ11) from the Magnum and the Atkinson that ran from the wheel well to the upper cabinet in order to use with the head units for the BMV712 and for the Victron VE.Bus to USB converter that goes to the Raspberry Pi running VenusOS. I was on the waiting list for the new Cerbo GX and the Touch Control, but quickly realized that they were charging me over $200 for the touch screen that I bought on eBay for less than $40. The Raspberry Pi has been a learning curve, but I have enjoyed making it work. I am in a little bit of uncharted territory since the Venus was designed for the Pi 2 and 3, but all I could get locally was a Pi 4. I am happy with it and saving > $600 by doing so. Once we are able to leave the house again, I'll set up the Kenwood to read the status webpage of the Raspberry Pi so I can see what it is doing while I am driving down the road.
As it sits now: 276 AH lithium and the ability to run the roof top AC and the microwave from the battery with minimal impact to storage space. Goal accomplished. My wife won't even know things changed.
Near Future:
I bought 8 Valence batteries. 6 were installed in our Class A and that left me with 2 extra for the AS. The Class A is up for sale so I removed those 6. I discovered that I have one battery with 2 failed cells - but the other 2 are still good. That leaves me with 5 more batteries that I can install in the AS, maybe with a battery cart/tray that will bolt up where the generator was connected through a few 175amp Anderson connectors.
rowiebowie 04-05-2020 10:27 AM
Welcome to the forum Chris!
Nice job and great first post. Always hard to fit components in the small confines of a class b.
Just a few questions on your install (maybe I missed them):
- Do you have enough ventilation for the Inverter/Charger?
- What gauge wire did you use (looks a little small) however runs look short?
- Have you considered temperature of lithium batteries if you eventually place more in the old outside compartment?
- Did I read that you've wired your fridge to only run on shore power? I guess you mean to have the inverter on at all times?
Finally, just know you'll have very limited run time for a/c on just the two batteries in your initial install.
Chris Blank 04-05-2020 11:10 AM
I took the top (now right side) cover off to allow for airflow. Air can flow from the rear vents on the left through the inverter and up through the top of the cabinet. I don't anticipate heat issues, but if there are, they could easily be solved with a small fan to force cooler air inside the cabinet. The inverter already has a fan on it.
Doubled 0/1 Awg on the Pos and Neg as directed by the Victron install manual.
Yes, that is primarily why I decided to place them inside for the time being. I can conservatively get about an hour of AC use per battery so I thought about a summer battery cart or tray to add on as a module. Maybe even a hitch battery carrier is one of the options for those times when I need the extra capacity.
No sense in running the 2-way fridge off inverted 120v when it can run just fine on 12v and then run off shore power when plugged in. The Victron has a pass through circuit so that the inverter does not power those loads but allows the shore power to pass through and power them. Just like there's no sense in heating the water with inverted power, but there is a benefit of saving LP when plugged in.
I have had several Class A's, so we are used to certain conveniences. Having AC power is one of those.
Boxster1971 04-05-2020 11:19 AM
Nice work - certainly a big project.
FYI- the limits of the Nations second alternator to run the roof top A/C was identified by Advanced RV four years ago. That is why they developed a large Delco alternator installation for the Sprinter V-6 diesel. It is detailed in this YouTube video.
https://youtu.be/XANYxoEF_HY
rowiebowie 04-05-2020 03:21 PM
Looks like you thought of everything. I just know how Airstream likes to cover everything behind panels. I too had to remove some for ventilation during my lithium upgrade.
I like the idea of a "Summer Pack" of additional lithium batteries. Since you already have them, it will just take an inventive solution to make it a practical swap in and out of your old battery compartment or generator box. You've certainly taken out much more weight than any extra lithiums will come close to adding.
Let us know how it goes.
Teamaron 04-05-2020 04:59 PM
Would love to do this but not that tech savy.
Can you share appt. cost?
Where would one go to get this work done?
rowiebowie 04-05-2020 05:58 PM
Unfortunately, the cost is great and cannot be justified. But then, that could be said about much of rv life.:) My cost was nearly $2800, and that is doing my upgrade to a modest 200Ah, cheaper components, and my own labor.
My upgrade started out as a modest desire to run the 700W microwave (that actually pulls about 1200 watts) without being plugged in or starting the generator. I also wanted to get rid of 150 year old lead-acid technology and double my usable amp hours so we could boondock more than one night. Modest goals I thought.
All parts of my project are Renogy. Mainly because the Renogy's were the only products that fit the space I had available (and their prices are right).
Summary:
Inverter/charger - Replaced the old 750 Tripplite with the Renogy 3000W Pure Sine Wave Lithium Compatible R-INVT-PCL1-30111S-BC. Currently on sale for $719 (free shipping https://www.renogy.com/3000w-12v-pur...w-lcd-display/). It happened to just fit the long and fairly skinny space I had available. Overkill for now, but I wanted the 3000W in case of future upgrades.
Truly an easy plug & play replacement for the Tripplite. It is easily programmed from it's top LCD screen. Charger rates can be set in 5A increments up to 75A. A comparable Victron will run you about $1300. A respected product, but at nearly twice the cost.
2 x 100Ah Lithium Batteries - Besides being on sale for $719 at the time I purchased, Renogy had the only true Group 27 sized batteries I found (actually slightly smaller). Battleborns, besides being more expensive, simply wouldn't fit externally or internally in my application. I ended up installing the Renogy's inside, next to the inverter, by re-purposing a small storage compartment. Misc. 4/0 cables, ANL fuses, etc. were another $150.
DC-DC Charger - At the time, Renogy offered 20A ($129) and 40A ($179) models. I chose the 40A since I figured the 20 wasn't enough and the 40 would still not over-tax my engine alternator. I effectively isolates the lithiums from the lead-acid engine battery bypassing the old Isolator to which the Ignition switch was wired and running a new ground to the chassis.
State of Charge Monitor/Shunt - To track the lithium charge levels, I purchased the Renogy 500A Monitor for $99. Comes with it's own shunt which is wired to the negative cables. It handles 500 amps and can be programmed for up to 9999 amp hours of battery, so again, I won't have to replace it if I add future battery capacity.
Unexpected Discoveries during install:
While the install when pretty much as expected and there was no smoke or fires, moving the batteries inside and disconnecting from the chassis battery resulted in the following unwanted, but necessary changes.
1) The engine battery no longer charges when plugged in. It still charges from the alternator and I routed my meager solar to it keeps my engine battery charged while sitting for extended periods.
2) One of the major reasons for the upgrade was to run the microwave from the inverter. But I soon realized the plug behind the microwave is not on the inverter curcuit. So I temporarily ran an extension cord behind the cabinets to the a wall outlet connected to the inverter. A permanent fix will have to wait.
I love how fast the batteries charge with the new system. We don't plan to run the inverter except to use power-hungry appliances like the Microwave for brief periods.
Chris Blank 04-05-2020 06:51 PM
Well, I'm in Biloxi until about August.
I'm military - an aircraft fabricator turned cyber nerd. I need to have these types of projects to get me along.
I didn't buy everything at once, but general costs are:
Inverter: -$1100
BMV712 -$180
Cableling -$100
Raspberry Pi -$56
Touch screen -$39
batteries -$300/ea
Nation's alternator $1900
Sold generator and magnum +$1000
Rough Total is just under $3000.
I still have some odds and ends that I can try to sell in order to recup some more costs. Obviously, doesn't include labor
We got a good deal on the van to begin with, so I justify the cost by figuring it in as part of the purchase price.... in my head anyway.
Teamaron 04-06-2020 04:39 AM
Inverter: -$1100
BMV712 -$180
Cableling -$100
Raspberry Pi -$56
Touch screen -$39
batteries -$300/ea
Hi Chris
Does this mean your done in south Florida area in august? And can do on our interstate?
Kurt
Chris Blank 04-06-2020 06:05 AM
Originally Posted by Teamaron (Post 2348301)
Hi Chris
Kurt
Not quite... I won't find out where we are moving to until the end of June... yes, about 30 days notice for us to prep for a move - it's great :huh:
Chris Blank 04-06-2020 07:11 AM
Kurt,
Send me a PM and I can try to help you through your project.
LB_3 04-18-2020 10:31 PM
Sorry I missed this thread earlier. I don’t get on the forums much right now. Work has just been too busy this past year.
Thanks for the complement. I’m not a pro like Lew but given how much I value my free time, I try not to waste it doing crappy work. I also try to learn something new with each project wether it’s welding, water jetting, phosphate coatings, etc...
If you’re reading my thread, I would advise starting at the end or reading all the way through since some of the stuff at the beginning is wrong and not corrected until dozens or even hundreds of posts later if at all. It’s really unfortunate that the mods don’t allow edits after the first 30 minutes.
Oh, and more pics are always nice.
Edit to add that I’m quite jealous of your ability to add a second alternator. That’s not a very viable option on out T1N.
LB_3 04-20-2020 08:56 AM
Btw, once you get the Pi4 up and running, satisfactorily, you may want to consider selling kits. There is quite a bit of capability in those devices but as you noted, the learning curve is a bit steeper than most DIYers are willing/able to achieve.
You may be saving $600 but you’re also creating some intellectual property that may serve the needs of this niche market.
Chris Blank 04-21-2020 06:14 AM
I have the RPi4 up and running with a 5" touch screen. The official screen is a 7" that will support dimming and turning the screen off. Currently, the 5" screen does not do that, however it does not take up much power anyway.
I'm willing to put together some kits, but need to know what people need or where they get stuck when they try to do it themselves.
lachness 05-05-2020 07:36 AM
Chris,
In your rework of the electrical system did you make all the outlets live through the invertor when boondocking? If so how big of a wiring job to accomplish that piece.
thx
Lach
Chris Blank 05-05-2020 07:50 AM
Yes, all outlets are live through the inverter. I removed the original fuse/circuit panel and made my own. Since the replacement inverter has a built in transfer switch, you can wire it inline with the shore power inlet. It just takes a little bit of studying the AC wiring diagram.
Heckler56 06-14-2020 10:56 AM
Chris,
Assuming all of the electrical system is calibrated for lithium, are the Valence batteries able to plug and play? Looking at the Muller site online they appear to have connectors and not posts. I also was curious if any additional items need to be purchased from Muller to allow these to function properly.
Thank you,
David
Hawk-ination 06-14-2020 10:13 PM
Really interesting post and project. Thank you for sharing. Been looking at alternatives to upgrading although this project would be beyond my capabilities! Please let us know when you’ve completed your goals.
Chris Blank 06-15-2020 07:03 AM
David,
Nothing is really plug and play. The new batteries are completely separate from the chassis system and have their own alternator. The Victron equipment and the alternator has to have the correct voltage settings for whatever specific battery you install. Some of the default settings will work, but it will work better if you customize it for your specific batteries. The valence batteries have bolt type terminals that work with 5/16" ring lugs. The connectors that you might see are to get diagnostic data from the battery to see things like state of charge, number of discharge cycles, temps, and individual cell voltages.
Heckler56 06-15-2020 01:35 PM
Originally Posted by Chris Blank (Post 2371624)
David,
Chris,
Thank you. Would I need to buy the battery diagnostic equipment from Muller or would Victron or Trimetric products achieve normal soc & temp readings? I would expect the discharge & cell voltages would require their proprietary diagnostics.
David
