-   -   Antenna connection (https://www.airforums.com/forums/f37/antenna-connection-2052.html)
PatCrusse 10-10-2002 03:31 PM
Antenna connection
Call me ignorant, or just call me dumb.
I cannot figure out how to use the antenna on my '74 Tradewind. There are two locations inside the trailer that have a white plastic box. The boxes both contain a 12volt socket and two holes that say "antenna." How do I connect my TV to the "holes?"
Patrick
Chas 10-10-2002 04:08 PM
Mine had that same setup which I replaced when I put a amplified weingard antennae setup on it. I think those holes take some sort of a male banana connector.
Chuck 10-10-2002 04:15 PM
yeah, its an old-style plug for the flat-wire cable. can't get them anymore...
What I did was disconnect the antenna wire from the back of this plug, and connected it to a 300ohm-75ohm converter. (radio shack) This has 2 screws on it to which you attach the antenna wires (doesn't matter which wire goes to which screw), and a coaxial type plug to which you can connect a modern coaxial cable to your tv.
Someone posted a link here once to a catalog outfit that had the entire 12v outlet/coaxial connector wall plate. If they don't make one that is set up to have antenna wire connected to the back of the plate, you can always use the converter I mentioned, and just hide it behind the wall.
