-   -   Replacing awning fabric (https://www.airforums.com/forums/f442/replacing-awning-fabric-20500.html)
SteveS 01-29-2006 04:36 PM
I have an A&E 8500 awning on my '62 Globetrotter. The material is old and starting to tear at stress points. Can I replace just the fabric? How difficult is it to install on the roller mechanism? It looks like some disassembly of the roller is required to slide the old fabric out and new fabric in.
davidh 01-29-2006 05:01 PM
Awning
Welcome to the forums. Go to this site if you have zipdee awning click on services and determan which awning you have but fabric removal is the same on both this site has all you need to know about your awning..https://www.zipdeeinc.com/
atvmcg 01-29-2006 05:09 PM
I replaced mine this year, ZipDee will ask you the right questions for awning size and material design. You should also check your hardware while replacing...especially look at the springs which rust out over time.
Rob30044 01-29-2006 05:12 PM
I replaced the fabric on a A&E 8500 awning on a trailer that I no longer own. Be very careful. First thing is to remove all the tension from the roller. I think my roller had springs at both ends. The rivets have to be drilled out of the end caps of the roller for removal. I cut the old fabric from end to end for easier removal. I removed it from the roller and then from the awning rail. Installing the new fabric is much easier if you have someone to help. I did it by myself. The new fabric has to be threaded through the roller grove and the awning rail. You will have some extra cord at each end of the fabric at the roller. Do not cut this off. Tuck it inside the roller before you replace the roller caps. This will keep the awning fabric from sliding in the roller groove after installation. My awning arms were marked at each end at the roller with an arrow. This shows you which way to rotate the arms to add tension.
Ben
SteveS 01-29-2006 05:46 PM
Thanks for the quick replies. I checked out the Zipdee site, and apparently I should call them with dimensions and they will make to order. Rob30044, did you use Zipdee material to replace your A&E awning - are the slots in the roller and on the trailer the same size? The Zipdee site shows metal slats as part of the top edge of the awning but my A&E is all fabric, it just slides into the groove on the awning rail on the trailer.
Rob30044 01-29-2006 05:57 PM
I don't think you would be able to use Zip Dee fabric unless they make a fabric to fit an A&E awning. The awning rollers are completely different. The Zip Dee awning roller slides into a pocket in the fabric and is then held in position by several pop rivets along the awning roller. I ordered my awning fabric for the A&E from Camping World.
Ben
