-   2018 - Current Globetrotter (https://www.airforums.com/forums/f543/)
-   -   2020 shakedown list? (https://www.airforums.com/forums/f543/2020-shakedown-list-204239.html)
Garfish 01-05-2020 01:15 PM
Picking up next month and will do overnight at dealer checking everything out. Not my first AS but would like to know of anything to watch for from those that have owned this or 2019 GTs. Mine will be 25 twin but assuming 27s will be similar
jeffmc306 01-05-2020 02:40 PM
Garfish, congratulations on your new Globetrotter!
You know the basic drill, check all the appliances, furnace and temperature dependent, heat pump. The A/C will likely work if the heat pump does.
You'll be getting the power awning so definitely cycle that a few times. Ours has a strange behavior where it periodically stops retracting about two feet short. It will close if you press open / close again. I've contacted ZipDee (sent them a video of it in action) and they promised to have their expert contact me. Still no reply after two calls...
Other than that, check the interior for fit and finish. I found a screw tip sticking out from under the galley cabinet. I slid a wedge under the cabinet and hit the screw with a punch. Problem solved!
Later, I found another screw under the flooring near the bathroom door. I was able to move it along with a dental tool until it got under the bathroom door frame. Also, after a few months we found ripples in the flooring from the twin beds to the bathroom area.
One last thing to check: Winterizing valve. Airstream installed them backwards and I don't know if they ever corrected it. Check yours while you are at the dealer to save you a trip next Fall. The handle should be pointing towards the water pump. Mine is going the other direction (see photo). This is a common complaint among GT owners...
Good luck with your new trailer!
Garfish 01-05-2020 05:49 PM
Great stuff, thanks
ExploreUT 01-06-2020 08:16 PM
Picked up our 2020 GT 27 FBT in August. The only issue that has arisen was the Demco coupler recall which our AS dealer fixed last month.
The flooring issue described is limited to models prior to 2020 I am told. Our unit does not have the problem.
So far so good............
hanktheyank 01-12-2020 01:43 PM
Check your battery paralleling cables, the ones that run from pos to pos and neg to neg. AS saves a few pennies by making them short and straight, which prevents you from opening the caps on one of the batteries without removing the cables.
In my case, the pre delivery guy assumed that since the “easy” battery had plenty of water, no need to pull cables and check the other. And since the factory guy apparently did the same, two months later, I had to buy new batteries— not covered under warranty due to abuse.
If the cables block filler caps, make them install longer ones that bend away from the caps so that nobody else avoids the “hard” one.
Garfish 01-12-2020 10:50 PM
I already have the ones from my last AS I did, golf cart. Thanks
RCC 01-29-2020 10:52 AM
Our 2019 25í GT had battery cables blocking vent caps:
Attachment 360128
So we turned the curb-side battery around and used the orig cables so we have easy access:
Attachment 360129.
I would also echo the winterizing valve comment above. You should ask them to show you the valve. Ours was not visible or reachable from the nice access panel under the hall closet. It is under the refrig behind the cabinet. A placard, like this picture from the manual, should be attached near the valve so you can tell if it is backwards:
Attachment 1
If it is backwards they will have to modify the back of the cabinet to get access to the plumbing and you will want that modification to not only look nice but be designed so you can easily get back there yourself for future winterizing and to access the screen/filter before the pump.
TheTinman 01-29-2020 11:10 AM
more thoughts
I have a 27 2018 GT which had a recall on the overhead kitchen cabinets, there are pictures on here with cabinets that have fallen. Checkout the leaking roof vents on the GT's as well. Batteries, awning, have already been mentioned. The undercounted sink on my unit came loose after a year which I just reinforced with some wooden supports screwed underneath. Unfortunately for me I had all the above happen as I travelled in my first year but now I think I have it covered. Other than that take her down the road and see what shakes loose. If you need any clarifications or pictures just drop me a line. I think if you follow everyones advise that posted before me your unit should be rock solid.
Garfish 03-08-2020 02:38 PM
Screw job?
Next week is shakedown and washed my 25 GT in my driveway today. First time opened the segment protectors. As I was about to close the second one I glanced at the mounting hinge. Seven screw holes and two screws. I looked down the other hinge and saw four
Maybe end of screw guy’s shift and wanted to get home?
Love my GT and expect to find some other things over time. Just the way things are and just surprised, not complaining. This does make me want to look at all screw holes though
jeffmc306 03-08-2020 08:08 PM
Found your missing screws!
Garfish, hey I think I know what happened to your missing screws:whistling
I found one sticking out from the kick plate by the kitchen and another under the flooring in front of the bathroom door on our GT.
Honestly, I cannot believe what you found. Maybe missing one but a whole row? Must have been break time and when they got back, forgot where they left off and closed the guard.
Hope thatís all you find missing!
Jeff
Garfish 03-08-2020 08:41 PM
Not comforting
GettinAway 03-09-2020 05:15 AM
Now I’ve got to go look. ��
Garfish 03-22-2020 03:29 PM
Shake down on hold
So decided to do this
olgoat 03-22-2020 05:00 PM
Garfish, would you mind sharing a link or part number for the struts you installed over the refrigerator?
Stan
Garfish 03-22-2020 11:06 PM
Apexstone 45N/10lb 10 inch Gas Struts,Gas Springs,Gas Strut,Lift Support,Gas Shocks,Lid Stay,Lid Support https://www.amazon.com/dp/B01H18I46K..._aoeEEbS5S09AG
link2dks 03-23-2020 08:11 AM
Very nice upgrade, have done this myself but only one strut is needed. I gave the other one to a friend who had a GT.
Garfish 03-23-2020 11:54 AM
I needed two (45N) as door would not stay open with one
Garfish 03-23-2020 11:56 AM
Bumper storage wet
Thought that the door on the storage looked like it might let water in. Since I donít put things there that water is an issue still had to remove everything to dry out after rain. Any solutions?
rmkrum 03-23-2020 12:01 PM
Drill a few holes to let the water right out if there are no drain holes already.
Remove sharp edges of the holes and paint appropriately to rust proof.
link2dks 03-23-2020 12:09 PM
I should have checked your link before I posted :bangin: I used a single 80N/18lb strut which is working well for me and 3 other GT owners that I know of.
This one
I am surprised the single 10lb strut wasn't adaquate.
What ever works ;)
Dave S
