-   2018 - Current Globetrotter (https://www.airforums.com/forums/f543/)
-   -   2020 GT27FBT - Unprotected electrical cable shorts on exposed aluminum sharp edge. (https://www.airforums.com/forums/f543/2020-gt27fbt-unprotected-electrical-cable-shorts-on-exposed-aluminum-sharp-edge-204026.html)
Lamar 12-28-2019 08:08 AM
This is probably true for more than just Globetrotters but I thought I would post here since it is more of a poor quality control / craftsmanship issue than anything. So you need to be aware of the electrical cable routing from your tongue jack, 7 pin cable, and safety brake switch where it passes under the LP gas tank shroud. There is a small half moon shaped cut out At the bottom of the aluminum shroud with no protection for the cut edge. There is a bare sharp edge at the pass-through. Some cables that pass through have plastic armor but the power supply to the tongue jack had no armor and within less than 6 months has worn through the insulation and shorted. See linked video.
https://youtu.be/nLwBrUQMJ8Y
I repaired the cut, replaced the fuse, put armor on the tongue jack power supply, and opened up the rather small cutout to provide more room. This should do until I can get Airstream to evaluate and provide a proper solution. What worries me now is how many more of these electrical short Easter eggs are lurking in the trailer. I know there was post a while back about a fire that destroyed a Globetrotter. Certainly this is just one of many quality issues I have had. Over the last 5 months we made 8 trips, 3 trips have had schedule impacts due to problems and Iíve had to cancel one trip. Not very good for any new vehicle but extremely disappointing for one that costs near $100000
UncleBad 12-28-2019 08:34 AM
I took a rubber grommet of the correct size and cut it in half and put it over the sharp edge of the propane cover. Others have used fuel line.
I also have fuel line cut down one side on the propane cover bottom where it rests on the frame to protect the frame.
Downhill502 12-28-2019 08:49 AM
Since we are picking up our Globetrotter 27 next week I appreciate this information and will bring edging trim along with us. Care to elaborate on the other issues you have encountered?
Lamar 12-28-2019 01:46 PM
If youíre picking it up new just tell your dealer to fix it before you accept delivery. Airstream needs to get these issues reported through dealers so they understand thereís an issue. Show them the video.
Iíve had only one other major issue. The hitch would separate / come loose when properly locked down. There was a manufacturing defect with the hitch. A new hitch coupler had to be welded on the trailer. Check to be sure your hitch doesnít have excessive play when latched before you leave the dealer. Search on me to find the post.
Several other minor issues that were resolved but annoying just the same.
Attachment 358279
DORA-1 12-29-2019 10:12 AM
Woofer Cable
We have a 2017 25 Flying Cloud which has had very few issues to date. Because this wonderful and sometimes frustrating piece of equipment is rocking and rolling down the road over thousands of miles Iím always checking it for maintenance and safety issues. Too this end I offer the following: upon crawling under our table to check on the woofer speaker I found where the woofer cabling came through the wall was unprotected from the sharp edge of the wall. I retrieved some plastic armor ribbon and insulated the woofer cabling before who knows would happen.
Be vigilant and safe travels.
bibbs 12-29-2019 12:21 PM
:angry:That is poorly done, on my 71' that wire was fed through the frame. Must cost more to fish it. They should have put some sort of protection for it. Might cost them a dollar of two. That would give the bean counters major headache
cwf 12-29-2019 03:20 PM
Sparky things adjacent to propane fuel. Comforting...
goransons 12-29-2019 06:05 PM
Had not noticed that little detail on our 2020 until this post. Thank you! I just removed the cover until I can get some edge welting on the cut, but ours appears to have been done with sharper tools or a more skilled hand...
Attachment 358343
SteveSueMac 12-29-2019 09:16 PM
Had the same on my 2012 27FB. Terrible design. I had to repair the cut cable (yes - sparky things near propane tanks!) and wrap the cable in thick reinforced vinyl hose. Grommet would have been a good call.
turk123 12-29-2019 10:50 PM
Items that you repair yourself are items that you need to report to customer service or the service department. Making them aware of it will help them get involved in solving the problem.
I always make it a point to call Airstream when I uncover an issue with quality control. Everyone should also get involved when you are concerned about an issue.
As an example, I reported a problem with my shower door sweep being torn by the door slipping down too far. Customer service not only sent the sweep but the fix for the door. Two small blocks to be installed under the door. You benefit by reporting.
ddrg 12-31-2019 06:58 PM
That's sad :-)
On our 2018 GT, the break away cable and the jack motor cable were each individually enclosed in plastic split tubing flexible conduit covering.
Gdarbro 01-04-2020 08:13 PM
I also noticed that the propane cover on our 2019 27FB GT was sharp where it came in contact with the 7-pin wire. After removing the tank cover, I found the appropriate grommet had slipped backwards into the A-frame area. It was easy to put back in place, but I could see where it might slip back each time the cover was removed. I plan on taping a length of heater hose to the wiring along this area to keep it from cutting the insulation with road vibration.
AirstreamInc 01-06-2020 10:32 AM
Hi Lamar,*
We're very sorry to learn about the issues you have had. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team.
Thank you.*
GOUSC 01-06-2020 06:39 PM
Originally Posted by ddrg (Post 2319837)
That's sad :-)
^^^^Same here with our 2018 GT. Looks they either skimped on this in 2019 or was a slip up on yours.
