for anyone considering a solar generator
I have been researching Goal Zero and other brands of solar generator/battery packs. This seems like a great value and i took advantage. Wanted to share in case anyone else has been considering a solar generator.
https://www.kickstarter.com/projects...or/description |
Just a cautionary note about Kickstarter projects: don't expect delivery on schedule. These kinds of tech projects often ship six months to two years after the promised delivery date. That doesn't mean their promoters are trying to cheat you, but unexpected technical and production snags are par for the course with Kickstarter projects.
In short, if you need a lithium-based powerpack this year, buy a known brand off the shelf. If you absolutely must have a Kickstarter "early bird" bargain, be prepared to wait for it. I've backed a couple dozen Kickstarter projects over the years, and I speak from experience. |
But how does it operate? Do you hook it up to the Airstream batteries to charge them or do you plug it into the electrical socket on the exterior of the trailer as you would in a campground with hook ups?
Hi
A bit more caution on Kickstarter: You are fronting these people money. Your "donation" goes out when you hit the button. They may or may not send you anything down the road. If they send you nothing, your ability to get your money back .... not so much .... ===== It appears to be no different than other solar to battery to inverter "power packs". Calling them a generator confuses more than it helps. Bob |
Vaporware
Pat |
and as a backup it the trailer batteries are depleated. I have a solar suitcase that will recharge the unit. I will also use it at home during power outages. |
"Goal Zero" search results on this site:
https://www.google.com/search?q=Goal...=airforums.com https://www.airforums.com/forums/f448...-193642-2.html Peter FYI FWIW |
Solar generator, eh?
Sounds like a battery to me. "Just plug in any solar panel to charge." "Recharges in two hours and provides 1600 watts of power." Pardon me if I spit my coffee out at that claim. |
I pledged three times on Kickstarter at much lower dollar amounts. One came through, the other two just went away with no explanation. For that much money, I'd be wary.
Looks like the same exact thing as the bluetti, except that you have to wait to get it.
https://www.maxoak.net/portable-sola...s/show/51.html You can buy a lot of 100w solar panels for that price though... |
Maybe one could pursue an FTC complaint against con-men purveying a "solar generator" that's neither a generator nor includes any sort of solar panel...
Some of the comments are very rigid. When you buy a generator does it come with gas? Is that false advertising if a generator just sits, doesn't generate, until you add gas?
A solar generator is the same. It sits, until you add the panels. The technology on battery storage units are rapidly improving and changing all the time. I chose to go with a solar unit as I have a small sport 16 and didn't want to mess with the weight, gas storage and transport, and the noise. Maybe try thinking outside of the box. |
Generator: a dynamo or similar machine for converting mechanical energy into electricity.There's a difference between "thinking outside the box" and "not thinking at all." I have a portable solar setup, and I use it instead of a generator whenever it's practical to do so. I prefer it because it's silent and clean, but I don't call it a generator. |
We've had a Goal Zero Yeti 400 for several years and love it. It's basically a AGM battery with several options for recharging electronics, monitoring what's being charged, and recharging the generator. We use it while boondocking to run led lights, satillite radio, and tv.
For great info on solar generators go here:
https://www.youtube.com/watch?v=sFBYjEK-HK4 |
For those with a solar battery, wouldn't dare use generator even if the solar panels generate power to charge the battery.
How do you integrate it in your trailer if trailer battery is low? I am thinking of adding a 12 volt lighter plug, to run lights etc. |
