-   2001 - 2005 Classic (https://www.airforums.com/forums/f252/)
-   -   Suspicious leak (https://www.airforums.com/forums/f252/suspicious-leak-200371.html)
Lthrncktrvlr 09-03-2019 02:59 PM
Suspicious leak
Over the weekend, I noticed an intermittent leak on my 2004 34' classic s/o from a weep hole in the center of the black and gray tank bottom cover. It was only sporadic and suds/bubbles formed on the ground. No odor, clear, intermittent. Not looking forward to dropping that cover so wondered if anyone had experienced this and knows already what's up?
rowiebowie 09-03-2019 04:15 PM
Suspicious leaks are the worst kind.:D
I own a class b not an AS trailer, so just tossing out the question of did anything unusual precede this event. Full tanks, rough road, sewer smells inside, right after a dump?
Lthrncktrvlr 09-03-2019 04:56 PM
Well I noticed it during a dump, and it was getting close to 3/4 full, the bathroom had a slight odor but I attributed it to having the exhaust fan on and it pulling air up from the floor. No rougher roads than normal.
rowiebowie 09-03-2019 06:00 PM
Hopefully, that information will help your fellow trailer owners. I'm hoping it is something simple like a valve or hose connection that needs attention.
Good luck.
rowiebowie 09-04-2019 07:30 AM
Giving your post a bump. Any leakage while it sitting after your trip?
Lthrncktrvlr 09-04-2019 08:10 AM
Thanks and no further leakage, I should have taken some photos.
