-   Airstream Classifieds (https://www.airforums.com/forums/f534/)
-   -   1995 Airstream Sovereign 21 - Montana (https://www.airforums.com/forums/f534/1995-airstream-sovereign-21-montana-200198.html)
Jamiwright 08-30-2019 01:45 PM
Title: 1995 Airstream Sovereign 21 - Montana
I just posted a new ad on Airstream Classifieds.
A modern cabin on wheels! This airstream has been extensively remodeled and modified with an open and modern interior and enough solar and tank capacity to expand your camping opportunities. Our family has outgrown her and we are sad to see her go!
With only 5,500 lbs GVWR she’s easy to tow, and the dual axles provide additional safety (hard to find on a trailer of this length!). The storage tanks provide remarkable capacity (50-gallon fresh, 23-gallon black tank, and 35-gallon grey tank) for a trailer of this size (a new Airstream has tanks about half this size), allowing for more time between dumping. To further add to the independence and flexibility of this Airstream we added 300 Watts of solar, with 200 Amp-hours of top of the line Lifeline AGM batteries, a Blue Sky solar controller and remote meter, and a Samlex inverter!
The interior has been transformed into an elegant and open space with an L-shaped couch and greatly extended counter space. The living area feels open and bright, with plenty of room for setting out a yoga mat on the floor! Simple and elegant features like magnets sewn into the curtains for closure and storage add functionality without clutter.
All-in-all she is in great shape, with scuffs and dings that come with normal usage.
Exterior and Capacities
• 21’ 9” long, including hitch A-frame
• 5,500 GVW
• Dual Axle
• Towmax ST225/75R15 tires and steel wheels
• Electric Hitch Jack
• Segment Protectors
• Two 30 Lb. propane tanks with gauges
• Lockable exterior storage compartment
• Classic blue Zip-Dee awning
• Rear stabilizers
Water and Tanks
• 50-gallon fresh water tank
• 23-gallon black water tank
• 35-gallon grey water tank
• Lockable water fill inlet
• 6-gallon water heater
• Shurflo 4008 RV Revolution bypass water pump
• Tank monitor system
Electrical
• 300W of solar panels (thee 100W panels)
• 200 Amp Hour AGM Lifeline Batteries (two 100 Amp Hour)
• Blue Sky Solar Boost 2512i Solar Controller
• Blue Sky IPN Pro Solar and Battery monitor with 500 Amp shunt
• Samlex 600W inverter
• 60 Amp Progressive Dynamics 9200 Inteli-Power Converter/Charger with Charge Wizard
• Xantrex Prowatt in-line remote power switch
• LED lights installed throughout
• Step light
• Updated grounded, GFI electrical receptacles work whether connected to shore power or when running off batteries
• In-line circuit interrupters for 12V and solar inputs
• 30Amp shorepower service line
Heating and Cooling
• Dometic Penguin roof-top Air Conditioner
• Hydroflame 31,000 BTU Furnace with recent motor replacement
• MaxxAir MaxFan Deluxe with built-in rain shield, 10 fan speed settings and direction reverse (super quiet!)
• Honeywell Thermostat
Kitchen
• Lightweight stainless steel sink with drain-board and built-in soap dispenser
• Sink cover
• Gooseneck faucet
• Built-in water filter
• Refrigerator: Six cubic foot Dometic with separate freezer, runs on either 120V electric or propane
• Three burner stove and oven by Magic Chef with stainless steel bi-fold range cover
• SilenX hood fan
• Magnetic spice rack
• Walnut countertop
Living Area
• Custom-built L-shaped couch with super-durable soft-shell fabric and storage drawer
• Walnut solid engineered floor
• Walnut-finished dining table with folding leg easily stows in custom cabinet when not in use
• Stainless steel folding cup holder
• Gooseneck LED reading lights
• Outlets with built-in USB charging ports
• Custom curtains have sewn-in magnets that pull the curtains snug against the wall for privacy when closed or to keep them tidy while open
• Skylight with accordion shade
• Folding coat hooks
Bed Area
• Custom cut 48” x 76” latex mattress with memory foam topper
• Two dimmable LED gooseneck reading lights
• Storage under bed
Bathroom
• Thetford Aqua-Magic Residence toilet
• Three chamber dispenser for soaps or shampoos
• Dimmable LED light
• Retractable clothesline
• Shower head with shut-off
• 12V exhaust fan
Safety
• Two fire extinguishers
• Atwood Carbon Monoxide and Propane detector
• Exit-able windows at each end of the trailer
• Exterior Surge Protector
Also included
• Original manual!
• Two Anderson Levelers
• 50 Amp and 15 Amp shoreline adapters
• Heavy duty Husky hitch lock
• RhinoFlex Sewer Hose with swivel fitting
• Wrench for water heater plug
• Additional fuses for water heater
• Replacement LED bulbs
• Happy Campers Organic Holding Tank Treatment
You can contact us by filling in the form on the right hand column of the ad listing:
https://www.airstreamclassifieds.com/...-21-montana-4/
