-   -   How to test the whole system? (https://www.airforums.com/forums/f287/how-to-test-the-whole-system-200046.html)
Swrider 08-26-2019 09:12 PM
Hello everyone. I was wondering how you go about testing the integrity of your LP Gas system.
We are in the process of cleaning up a '72 International Ambassador and i want to move on to testing the furnace and refrigerator, but before i do that i need to be sure that my gas system is good to go.
Do i just hook up the gas tanks, open them up and sniff around for leaks???
What about the furnace, im not even sure how u are supposed to tuen it on...
Any and all help/comments are greatly appreciated!
J. Morgan 08-27-2019 12:09 AM
Ideally you'd pressure test the lines by turning off the valves to all of the appliances and plumbing the line just beyond the regulator for a valve, an air line, and a pressure gauge, then pumping the line up to 30 PSI to see if it holds pressure overnight.
I didn't do that though. I turned the gas on and got busy with a spray bottle filled with dish soap and water..... meticulously checking every joint.....
Swrider 08-27-2019 11:00 AM
That's not a bad idea, of course since the oven and water heater lines are disconnected i would have to cap them off, but other than that it should be pretty straight forward. I already have a pressure gauge laying around that I can use. Just need to look at my gas connection and see how I can split that.
Ofcourse this will only check for leaks, finding them, if there are any, will not be fun.
Alumaholic 08-27-2019 11:24 AM
Do what J. Morgan described.
Then fire up every propane appliance in your AS one at a time: water heater, furnace, refer, cook top.
Then after you have confirmed propane at every point of use, and after you have turned each propane appliance off, turn off both propane tanks.
24 hours later, turn both tanks and confirm that you have immediate ignition at each point of use.
This is a field expedient way to determine if you are holding pressure.
