-   -   Brake Upgrades (https://www.airforums.com/forums/f311/brake-upgrades-199930.html)
MarshallSF 08-23-2019 06:52 PM
Brake Upgrades
Anyone ever upgraded the brakes on their rig? Iím in the process of swapping in a modified 8.1L vortec and wondering if thereís a way to upgrade my stopping ability as well? Dual piston calipers? Larger rotors? Everything Iíve seen is for smaller/thinner rotor setups - not much for 1.54Ē rotors as far as I can tell.
mayco 08-23-2019 07:51 PM
3-4 years ago I did a bit of research on upgrading the disc brakes on '82 310. Sorry to say that I got nowhere real fast, couldn't find anything at all in regards to caliper or rotor upgrades.
I'll keep an eye on your thread here. But there are numerous threads here on the forum regarding the finicky brakes on our P30s and I haven't seen or heard of anyone finding upgrades to the OEM system. Good luck though, hope you find a direction to pursue.
Mike
cmadmaxman 08-24-2019 09:24 PM
This was the best I could find for the front. Also new rotors on the rear, and all new pads. Definitely makes a difference. Attachment 350396Attachment 350397
MarshallSF 08-28-2019 08:44 PM
Those look pretty good - specs say about 1Ē oversized diameter from stock? Any problems fitting inside the stock wheel rim once the caliper is installed?
cmadmaxman 08-28-2019 09:37 PM
They are the same size as the ones I replaced. No problems with fitment.
