-   -   Several questions (https://www.airforums.com/forums/f240/several-questions-198678.html)
Mansderm161 07-26-2019 08:02 AM
Several questions
How do you remove shower curtain to wash? Mine has sewn elastic loops with a plastic insert that goes into the rail. Rail is crimped on both ends. Did you pry open on end of rail to slide curtain out or am I missing an easier way? Also my tank heater is coming loose. Looks like a rubber mat glued on. What adhesive do I need to reattach? Thirdly, there is a big metal ring near door. What is it for? Thanks. Attachment 347642Attachment 347643Attachment 347644
Tronadora 07-26-2019 08:12 AM
Shower Curtain: Yes, use a decent size flat bladed screwdriver to pry one end open. Use pliers to re-crimp after your reinstallation if desired.
Tank Heater Pad: There are many adhesives that will do the job. Maybe a can of 3M strong spray adhesive. Clean the surfaces with alcohol for best adhesion.
Cargo Rings: These are for whatever your mind comes up with... securing loads, attaching a dog leash, anchor point for a stretchy exercise band, etc.
Mansderm161 07-26-2019 08:42 AM
Thanks. Can't wait to try the stretchy exercise band in that! LOL. Going out now to pry the shower curtain out!
Atomic_13 07-26-2019 09:02 AM
Be careful to not stretch the heating pad when you reattach it. Stretching the pad may ruin the electrical heating element. These are expensive (~$100/pad).
TN Princess 07-26-2019 06:28 PM
From Lowe's / Home Depot, I purchased a flat sheet of metal. about the size of the heating pad. Used gorilla glue to reattach the pad. Then passed big and long zip ties around the gray tank including the metal sheet to help support the pad. Zip ties fore and aft.
Alex AVI 07-26-2019 08:34 PM
Eu
MANSDERM161 - Agree with all prior answers for shower curtains & cargo rings. As for hanging tank heating pads, I wanted to use Gorilla 38-lb. clear double sided tape but was out when I was at store. Ended up buying the 3M 10-lb clear double sided and still attached since my 1st week of ownership (03/18).
Mansderm161 07-27-2019 02:14 PM
Thanks. Tape looks like easy way to go
UncleBad 07-28-2019 09:52 AM
Found the Gorilla tape on Amazon.... https://amzn.to/2SKlT7y
wachuko 07-28-2019 09:57 AM
I used 3M spray adhesive... locally found at Lowes, ACE, Home Depot. Apply on pad and tank, let it sit a few minutes and put in place...
And just to be safe, I used black duct tape around the borders. Working great.
Titus 07-28-2019 07:11 PM
I used liquid nails in the small tube with the screw-on lid. Placed some supports under it to hold until the glue dried. Has held fine for ~ 3 years and 40,000 miles.
