-   -   Do I Need 4 Wheel Drive? (https://www.airforums.com/forums/f240/do-i-need-4-wheel-drive-197489.html)
1919 08-13-2019 03:10 PM
I have an Interstate 19 with 4 wheel drive. Bought it in California, drove it home to Washington State. Used the 4x4 to get into my driveway upon delivery! Don't really plan on driving it too much in the snow, mostly because of the nasty deicer that eats exposed wiring. BUT one thing is for sure, one probably will NOT drag their macerator, generator, hose reel, generator etc over a speed bump! The 4x4 19' is over 4 inches taller in the front and over 3.5 inches taller in the rear. This allows plenty of room to reset your generator breaker, and get to anything under the van without jacks. I even had to do a campsite repair to a failed grey water dump valve without jacks or ramps. Oh, and I did use the 4x4 function to get to my camping site at Oshkosh Airventure this year!!! 3 of my friends had to wait outside until the mud dried up!
SWH 07-28-2020 12:13 PM
I have seen a lot of people cite the increased ride height / ground clearance as a benefit to 4wd, and I can see the benefits. But I am equally concerned about possible disadvantages of increased ride height on the van's center of gravity. For those of you who have driven 4WD and 2WD Interstates, does the van feel any less stable or handle any worse at highway speeds? We are considering ordering a 2021 Interstate and I am leaning towards getting 4WD... if the only downside is cost, then we'll probably take the plunge and get it, assuming we'll likely recover most of the additional cost when we eventually trade/sell it.
The only other downside is reduced OCCC as we are planning to also order leveling jacks. 4WD reduces by 275 lbs and leveling jacks reduces by another 240 lbs. But that still leaves 1375 lbs OCCC which seems reasonable (and still better than an Atlas that has neither 4WD or leveling jacks).
SWH 07-29-2020 08:59 AM
This article is definitely making me think twice about opting for 4WD: https://ourkaravan.com/4x4_sprinter_and_transit_vans/
Sounds like marginal benefit for substantial cost and significant loss of OCCC.
Passin Thru 07-29-2020 05:32 PM
Last November we came back thru Utah on very snowy and icy roads. We have the Ext pulling a toad. I was very impressed with the solidness of the coach. We traveled at speed with no slippage. This is from someone who lived his first 50 years living in Montana with its icy winters and driving on icy roads in a variety of vehicles, some 4 wheel and many not.
I have a 4 wheel drive pickup which is nice for mountain hunting. We have a 4 wheel drive Acadia for general use. I have not felt the need for for a 4 wheel drive coach. Of course I donít plan to climb mountains with mine.
How will you honestly use it? It really comes back to that.
Rovin Raven 07-30-2020 07:29 AM
Nice to know how well the coaches do. Four wheel drive is definitely necessary is some parts of the country. Around here, in SW Virginia, it can be so muddy in the spring (nearly 60 inches of rain this past year) that I often need 4WD. There is also little flat ground. Our own driveway has a steep grade. The west is definitely dryer. But, there was a horribly muddy trailhead at Zion and we needed 4WD to get out of there, and we didn’t even venture down the road as far as others. We actually are moving west to be closer to our sons who live in Seattle and are thinking of switching to a coach for meandering around looking for a new place to live.
uncle_bob 07-30-2020 08:24 AM
Hi
Occasionally you will pull up and find that the campsite you reserved is all grass (no paving / no gravel). That may make for a slippery entry / exit from the site. If the tail end of a hurricane just happens to be going over at the time .. it *will* be a slippery entry / exit.
(Yes, this did happen to us ...The F-250 handled it just fine.).
SPARKLE19 07-31-2020 07:23 AM
You may never need it
I remember being in a Ford dealership looking at Expeditions while trying to figure out the best choice for towing a fairly large fishing boat (younger days), the particular dealer didnít have a 4WD in stock but had several 2WD models available. The salesmanís theory was ďyou would only use 4WD rarely ď, I agreed but pointed out that if you need it and donít have it.... that conversation has stuck in my mind over the years and I have always had a 4WD work or recreational vehicle while my ďgo to the storeĒ vehicles have MOSTLY been 2WD.
uncle_bob 08-01-2020 07:25 AM
Hi
Around here, if you want to buy a truck (at least one with a tow package on it), forget about buying a new 2WD off the dealer's lot. Even with a 600 mile radius search (which covers a lot of dealers ...) you probably will not have any luck. They simply don't stock 2WD in anything but the base / no options versions.
ROBERT CROSS 08-01-2020 07:42 AM
Just because it's 4wd doesn't guarantee you won't get stuck, shiftable low range transfer case, VERY important.
Three TV's all with low 4wd...TETO
YMMV
uncle_bob 08-02-2020 08:41 AM
YMMV
Hi
A lockable rear axle is a cheap option on most models. It's well worth the money, 4WD or not.
Hawk-ination 08-03-2020 06:42 PM
Depends on where you live and where you want to camp at. I can see it handy at times, like the person who stayed at the air show in Oshkosh, but personally, I do not think it is necessary for where we stay. The Interstate weights almost 9,000 to 10,000 lbs. (correct me if Iím wrong). Itís not like itís a 4 wheeling truck you are going to go off-roading with. If it has it, great, but I personally wouldnít make it a deal-breaker if it doesnít. Unless, like I said, you travel in the mountains a lot, need to camp off grid and off road, or possibly drive through a lot of snow. Although I dream of opening the back doors to wake with a mountain in the background, I would probably freak to drive my $$$$ Interstate through grass scratching the paint job to do so! They get pretty cold and the water freezes in anything below 32 degrees. There are members who camp and drive through snow, so maybe theyíd have a different opinion though.
albret 08-03-2020 10:42 PM
4X4 are great if you have a need. I pull my trailer up 10 - 18 degree slopes to my property in the mountains. It is necessary! Remember, you only drive in 4X4 at speeds under about 25 - 30 MPH. You do not drive on freeways in 4X4 mode. You drive on dirt and gravel roads because the front end slips/jumps when you make turns.
uncle_bob 08-04-2020 06:40 AM
Hi
Ok, so here's another story:
Google maps, our GPS, and the (non-existent) directions to the campsite all agreed that "turn here and go there" was the right approach.
We're in the Florida panhandle, nearest mountain is a *long* way away. Flat flat flat and flat are the main types of topography (also wet, but that comes a bit later).
Start down the road and it's not too bad. Pretty much your typical rural road. Been on a lot of them getting the "last mile" to here or there. Further we go the worse it gets. Seems the hurricane washed out this and that. It starts to vary between sand, mud, and "pond". No place to turn around. Not backing up 5 miles down a road with traffic on it (no we were not the only ones with GPS issues ... also seems to be some construction traffic .... hmmm ....).
Into 4WD low / lock the rear axle and proceed for .... another 15 miles. Pass various construction vehicles repairing this or that part of the road. Get a lot of strange looks from the crews. See various vehicles abandoned by the side of the road.
You can say "Bob, don't go out driving in a hurricane with your Airstream !!". That's good advice. The hurricane involved had come through 5 months earlier. They still had a *lot* of repairs to do ....
ScottP 08-08-2020 02:11 PM
Originally Posted by albret (Post 2392799)
4X4 Remember, you only drive in 4X4 at speeds under about 25 - 30 MPH. You do not drive on freeways in 4X4 mode.
Really?
Thatís an interesting opinion...
Attachment 375234
Above, Snow Monkeys in Japan north or Sapporo
Oh my, Iíve been doing it all wrong with my last four Airstream Interstate Lounge 4x4ís
Attachment 375235
I love winter ...
ScottP 08-08-2020 07:24 PM
Drivability -
You should prob test drive a 4wd Interstate*
My opinion is the 4wd Interstate offers a better overall driving experience when compared to a 2wd unit.
* difficult to test drive because theyíre so limited in production. So youíll prob recover much more than the option costs you.
Height increase isnít one of my concerns ... the van is already a ďSAILĒ and I donít know, are we talking about 1% extra height (somebody toss me a calculator please), which is of course negated by the electronics package anyway.
All versions of the Interstate are terrific - if you get out there and enjoy!
YMMV
NormanM 08-08-2020 08:19 PM
Ground Clearence Interstate 19 4x4
Does anyone know the ground clearance for the Interstate 19 4x4?
Tyvekcat 08-08-2020 08:23 PM
4wd ?
I currently have a 4wd drive truck, but I have always wanted to try a Dodge CTD 2wd dually. Mega cab longbed, would be the bomb ! :brows:
Smooth riding and stable low center of gravity,
I have seen a few, and wanted to buy a used one with low miles ( Ha Ha)
most are used to pull 5th wheels.
That would be my choice,
Glorious !
2wd would be fine with me if dually
best regards,
ScottP 08-10-2020 09:06 AM
Glorious !
best regards,
Traction - I agree the dually traction benefit from the 3500 Mercedes Chassis is terrific. Especially with good snow tires, and if necessary, chains.
I trust the FEDEX lead, where they run 2wd (the 2500 chassis) and it seems to work well for them! Even our FEDEX Ground guys in Jackson Wyoming had 2wd 2500 vans.
So Iím not sure for most people itís a required option. But as Iíve mentioned, I prefer the drivability of the 4wd, and yes I employ the option on the highway in heavy rain, and when the roads are snow covered or slick.
Amg 08-10-2020 11:27 AM
I have a 2020 Interstate 4x4 lounge. Never heard of limitation of speed while in 4x4. I know there is a limitation while in low range
pd_austx 08-11-2020 09:32 PM
Same. Dealer said limit it to 50 mph, but manual doesnít say anything. I limited mine to about 50 in a LOT of snow/ice this past year and everything seemed OK. But if anyone has anything from A/S or MB I would like to know.
Most 4x4 driving was under 30 (or typically slower) but did get on the highway a few times.
Was considering some good M+S tires to try and limit my 4x4 usage, so maybe for the upcoming season.
