-   -   Awning sun shade attachment (https://www.airforums.com/forums/f240/awning-sun-shade-attachment-197006.html)
Dena m 06-17-2019 11:02 AM
Has anyone attached a Zip Dee sun shade to their awning? Any other attachment ideas?
lsbrodsky 06-17-2019 11:23 AM
Yes, easy job. You have to drill some holes and rivet in some snaps so make sure you can access a drill and a rivet gun.
Larry
Schmitte 06-19-2019 08:49 AM
Iím also interested in this topic. Where did you install the snaps on the Fiamma awning?
lsbrodsky 06-19-2019 08:56 AM
I have a ZipDee awning and the snaps go right on the roller after unrolling the awning to deployed.
Larry
Schmitte 06-19-2019 12:01 PM
Ahhhh. You have a trailer. Has anyone installed a Zip Dee solar shade on an Interstate with the Fiamma awning?
Rig Rat 06-19-2019 12:32 PM
The Zip Dee web site says that the sun shade can be attached to an Interstates awning by using the cord that's sewn into the top of the shade. You can slide that cord into one of the 2 channels that run the length of the awning.
I wonder if the extra weight of the solar shade will have an effect on the wind sensor and make it retract more or less in windy conditions?
Our awning is so sensitive that it rarely stays open even in fairly calm winds!
So next time out, we're going to try staking the ends of our awning down to the ground and then pulling the fuse to try and enjoy the shade that it brings w/o retracting!
Good luck and please let us know how the sun shade reacts to the motion sensor on the Fiamma awning!
Mark
Dena m 06-20-2019 10:03 AM
More info on sun awnibg
I suppose that once the shade is slid into the spaces that a rivet gun is needed to secure the ends?
Also, does the Interstate awning reel allow enough room for it to roll up with the awning?
sheriff1 06-20-2019 10:10 AM
My zip Dee doesnít have an extra slot for this type, I got one that snaps onto the roller tube. You snap it back off before you roll it in.
gypsydad 06-20-2019 10:32 AM
We looked hard at this sunshade option, but we opted for the Costco 13' X 7' sunshade for $25 in dark gray similar to the ZipDee model. Using metal office binder clips the sunshade to the ZipDee awning overhang and we use bungie straps on upper corners to ends of the awning; metal steaks at either end on the bottom. If this doesn't last the summer, may opt for the ZipDee model... :wally:
Alex AVI 06-20-2019 12:00 PM
DENAM - I do not know for sure, but just eye-ball'ing my Carefree roller enclosure, it sure does not seem like there's much spare room in there. If anyone has successfully done so, would love to see pics.
turk123 06-20-2019 12:12 PM
Just be careful! I used a set of small forceps to hold the shade on temporarily. When the wind picked up, my wife woke me out of a sound sleep and I pushed the button to retract the awning. One of the forceps cut right through my 3 week old awning! :sad:
Rig Rat 06-20-2019 01:47 PM
I believe that you would have to remove the ZipDee sun shade prior to rolling it up in our Fiamma awnings.
Unless you went with this brand then possibly that little bit of attached material might retract into our Interstates Awning without causing any issues. However, I'm with Alex, I don't think that there would be much room for additional material to be safely stowed within our closed awning case!
https://www.youtube.com/watch?v=kHuhwv8Qi0c
Alex AVI 06-20-2019 03:26 PM
RIGRAT - I thought about it some more, then upon reviewing the YouTube vid you supplied, it became more apparent this would work on awnings with roller mounted on lead rail. But with those like mine where the roller is INSIDE a fixed enclosure that stays fixed on the roof and the lead rail that extends has a fixed external cap, it could be problematic since there is no place for the leader zip strip to wind into. However, I can envision a very, very short leader zip trip that may work. One that is so short, it literally is just a zipper mounted on the inside of our Carefree or Fiamma leader cap
gypsydad 06-21-2019 11:46 AM
Couple points:
1) either shade needs to be removed prior retracting the awning...even the Zipdee shade has grommets that have to be installed in the awning prior to use. Not sure if the ZipDee shade is worth the extra money yet over the Costco model, but will let you know how our "knock off" works for the summer.:flowers:
2) When wind picks up and awning is "a flapping in the wind", wife has gone out and tended to the issue..:D That being said, we don't have a power awning to deal with...(other than the wife!) But I will tell her to be sure to take off the clips and the sun shade prior to retracting, if a wind comes up again!:brows:
