-   -   Well, we did it. (https://www.airforums.com/forums/f311/well-we-did-it-19608.html)
guy99 12-11-2005 01:13 PM
Well, we did it.
Ever since we bought our 1984 310 Limited MH about 18 months ago, I have wondered about whether we would want a tow car. The purchase of the MH was an experiment for us to determine whether we liked RV'ing and to get an idea of what we would enjoy.
After last summer's trip to Washington DC, I began more and more to think about a tow car. On that trip we did fine without it (we once rented a car when we needed to have some work done), but I know there were times when we would have done more if we had a car available. Of course the 2000 lb tow limit makes selection of a tow car pretty limited. I first thought about an older, light vehicle like a VW or Tercel. My issue with that kind of vehicle is one of safety. These cars were made before modern safety equipment and it seemed a bad choice to take the additional risk of driving a light weight car without the best safety gear you can get.
After much searching I decided on a Toyota Echo. It weighs less than 2100 lb and is pretty roomy. Unfortunately Toyota has stopped selling them (they are being replaced by a new model - the Yaris).
So we went with the Scion xB. It weighs 2400 lb, is very roomy and we like they way it looks. It is equipped with 5 speed (according to Remco there is no way to make the automatic tow-able four down). We had an aluminum Blue Ox tow bar and US Gear Unified braking system installed and took our maiden trip yesterday. I noticed some effect of the weight in acceleration and engine temp when going up a grade, the braking system makes it unnoticeable when braking. So far, so good. You can see a picture here: https://tinypic.com/ifpv9v.jpg
uwe 12-11-2005 02:38 PM
Hey -they match!
guy99 12-11-2005 03:39 PM
Well, sort of match. They discontinued the color which matched even better.
noiva 12-11-2005 03:54 PM
What do you call them, the BIG box and the LITTLE box? How's your mileage towing the car? Also, what kind of temperature increases have you seen? I'm looking into the same idea, but probably with a dolly to deal with the weight of the car I have to use.
Tim
guy99 12-11-2005 04:40 PM
The motorhome is the "Silver Slug" (license plate AG SLUG) the car is the "Silver Box" unfortunately AG BOX is taken. We'll see.
A tow dolly doesn't increase the weight of vehicle you can tow, it decreases it by the weight of the tow dolly. Allowable tow weight is the maximum combined weight of everything you are towing. So you add the weight of the dolly and the weight of the vehicle.
I don't know what that rating is for your MH, perhaps since your chassis and power plant are different your MH is rated with a higher tow limit.
On a long, step grade gaining about 3000 feet, my temp got up to 210 degrees or so. When I shifted down a gear and kept the RPM just under 3000 (about 45 mph) it cooled off a bit. It was a very cool day.
I have only driven 120 miles so I don't have a fuel consumption calculation.
noiva 12-11-2005 04:50 PM
I understand what you're talking about with the weight totals. I guess I did a poor job of explaining the dolly plan. The dolly is being considered for 2 reasons. I do a lot of hills and mountains in the eastern U.S. I have an extremely low axle (5.29), so pulling the weight isn't the issue as much, although my rating officially is the same as most (2,000 lbs). It's just plain cheaper for me to have a braking system that I can get on a dolly than to go into all the expense of tow bars, and then adding a braking system to the car. I have to go with the cheapest system that provides braking. My research seems to favor the dolly. If money weren't an issue, I would probably go with on the ground like yours.
Thanks for answering my questions. Always looking for suggestions.
Tim
guy99 12-11-2005 04:54 PM
Thanks, Tim. I wasn't criticizing, just wanted to be clear.
No question the tow bar, base plate, and brake system was expensive. So was the labor to install.
juel 12-11-2005 06:21 PM
Don't know when that picture was taken, but gas is sure expensive where you are. It's about $1.87 here in Chandler, America.
Pick 12-11-2005 06:32 PM
Those look like Florida gas prices!
wahoonc 12-11-2005 06:55 PM
Or North Carolina:angry: :mad: I paid $2.65 for diesel here today...best I could find...gas is still over $2.15:(
Aaron:cool:
guy99 12-11-2005 07:07 PM
That picture was taken in Medford, OR
Astrodokk 12-11-2005 07:51 PM
Hi. I've sdriven through Medford. The Shakespeare Festival gets held around there each year.
I took my MH to a fabrication shop and had them upgrade my receiver to be able to take 5000 lbs. They did some frame welding and actually replaced the original receiver with a heavy duty one. Now I can tow my 1998 Jeep Grand Cherokee (4K lbs), but I sure feel the weight back there, since I only have a 28'. Eventually I would like to get a Toyota Prius to tow, but I don't know if it's possible on all four. Does anyone?
GlenCoombe 12-11-2005 08:21 PM
Yin and Yang
Guy99, looks like a cool combo....but the one up front is so STREAMLINED, while the one in the back is so ....BOXY!!
I pushed real hard for a Honda Element and Julie insisted on the Odessy minivan.
Great looking combo.
We're all waiting for the fuel mileage totals.
noiva 12-11-2005 09:18 PM
Back to towing with my 370
Guy, I didn't take the slightest offense about your information on weight totals. I learned a long time ago to pay attention to the people who actually have done what I'm considering. That's why I love this forum so much. Concerning the weight issue - I know the Airstream official recommendation for almost every one of their motorhomes is 2,000 lbs. The Airstream receiver is listed in the owner's manual as a Class I receiver, but it's really a class III:rolleyes: . Problem is that it's attached to the frame with very small elastic stop nuts:( . The beef is there, but the thing could very easily get ripped off the bottom of the frame if overloaded too far. I'm going to be pulling a Chevrolet Malibu (a little over 3,000 lbs), probably with a dolly to keep as much weight as possible from pulling DOWN on the rear of the coach. The strain will mostly be transferred to lateral pull vs tongue weight. I've been assured by many MH owners that they have successfully pulled under much more severe conditions than that for many years. I intend to replace the factory bolts on the receiver with much heavier duty stuff, use a dolly with brakes, and then hope for the best. Another vehicle isn't an option financially, and neither is a tow bar/car brake system. The extremely low gearing of the 370 should work to my advantage as long as I take it easy on interstates. I'm looking into a Gear Vendors under/over drive to give me a little relief at interstate speeds. That's probably where the real money will go. Sorry to run so long, but I wanted to lay as much out there as possible. Many folks have encouraged me and given advice about these issues, and I'm always open for more - especially BEFORE I spend the money:innocent: .
Thanks to all,
Tim (Noiva)
swebster 12-11-2005 11:35 PM
Gotta say that the retro curvey moho towing the cool modern boxey Scion is a very cool combination.
guy99 12-12-2005 12:11 AM
Tim,
I too have some very small bolts which appear to hold the receiver on, but, when I looked more closely I found that in fact my receiver is welded in place with a very stout weld.
Also, the tow bar/auto combination puts essentially no weight on the rear of the MH (about half the weight of the tow bar less than 15 pounds). The tow bar moves up and down and twists (rotates) freely so the auto and the MH can move independently. The tow bar merely provides a connection so that the two vehicles push and pull each other.
noiva 12-12-2005 08:06 AM
Originally Posted by guy99
Tim,
Thanks very much for this information. I haven't even slid under the hitch yet to study the attachment, other than to look at the small bolts. I hope mine is put on with welds also. Thanks also for the explanation of the tow bar setup. I knew the principle, but hadn't really thought about the weight applied to the rear of the MH. My obstacle to a tow bar setup is money. Also, I've heard from enough dolly towers to be reasonably satisfied that the setup works, and I can get brakes with the dolly. I really appreciate your time and expertise. Please let me know if you have other information or ideas that will help me as I decide about this - or any other issue. I'm very new to MHs. I've pulled trailers for 30 years, but, as you know, it's not the same:innocent: . Thanks again, Tim
ALANSD 12-12-2005 10:54 AM
the Scion is a stick I presume? Can their automatics be flat towed also? We are considering one of those for our next ride.
guy99 12-12-2005 11:15 AM
Alan,
Yes the Scion is a 5 speed. Per Remco the automatic can not be made flat tow-able.
noiva 12-12-2005 02:56 PM
Receiver welds
Tim,
guy99, Just got a chance to slide under the coach and take a close look at the receiver. You are absolutely correct about the welds in addition to the bolts. I couldn't see them by just leaning down in my previous explorations. That should be plenty secure for towing a four wheel on the ground or a dolly, as long as it's not over about 5,000 lbs. I'm estimating, of course, and the manual still says 2,000 lbs. I am NOT recommending towing 5,000 lbs, just the amount of weight the receiver can likely take. Besides, vertical weight (pushing down) is murder on the tag axles, so the tongue weight on the pulled object becomes critical, as you know. However, the manual also claims the receiver is a Class I, which it's not. Thanks for getting my curiosity up. I wouldn't have discovered the welds until I was well into beefing up the thing. Not necessary for what I'm planning, of course. Thanks again:flowers: ,
Tim
