-   -   Under Carriage Lights Won't Turn On (https://www.airforums.com/forums/f240/under-carriage-lights-wont-turn-on-195182.html)
GoingPhishin 05-03-2019 11:43 AM
I can't get the under carriage lights to turn on. I have power to the switch, so it is not the little battery behind the switch that needs to be replaced. I can get the awning out and the lights on the awning to work, so I do not think it is a fuse issue (I assume they are on the same fuse).
Any other ideas?
Thanks!
busb2 05-03-2019 02:18 PM
Suggest you replace the battery, I did when I had the same issue and that was the solution.
GoingPhishin 05-03-2019 03:04 PM
Just to be clear, you are talking about the little round battery (watch battery type) behind the light switch?
busb2 05-03-2019 03:25 PM
Yes, easy to do, I didnít know they were there but found a thread about it on this forum. You can use the search function to find the thread.
GoingPhishin 05-03-2019 04:30 PM
Thanks. I will try that this weekend and let you know if it works.
swilly43 05-04-2019 08:16 PM
Donít bother
I replaced this light strip once. It failed again and I thought why bother. Poor implementation of a vanity feature. Not worth the effort. I live in San Diego with limited exposure to wet environments
randkell1 09-19-2020 08:41 AM
My chassis and awning remotes needs to be replaced (broken, not a dead battery) which requires my new remote to pair within 5 seconds of when I turn the power on. I was able to pair the awning but the chassis did not pair. Where is the chassis eco-led light module located to replace it and where does the power come from, breaker or fuse location?
