-   -   Leaking from fixed non-opening windows (https://www.airforums.com/forums/f456/leaking-from-fixed-non-opening-windows-193154.html)
neetie sweet 03-13-2019 03:32 PM
My 68 safari has a small amount of leaking but I think it is only the lower non-opening parts of the window. I'm just seeing a little water collecting in the window sills but the upper opening windows look dry inside at the lower corners. Do the non-opening windows need to come off for resealing, or can i run a bead of some kind of sealant around their frames?
GMFL 03-13-2019 03:45 PM
Try captain trolly’s
https://www.airforums.com/forums/blog...nt-right-2995/
