-   -   Atwood water heater making noise after flush (https://www.airforums.com/forums/f445/atwood-water-heater-making-noise-after-flush-192618.html)
dsatwork 02-26-2019 11:15 PM
After flushing the water heater and buttoning it all back up, the gas flame became unruly and noisy. Not sure how flushing the hot water heater caused this issue. Any constructive advice is welcomed. Check out the link below for a video of what I was describing.
https://drive.google.com/open?id=1zc...WBKnXTl4Q8t2Td
Thank you.
Dave
OTRA15 02-27-2019 04:58 AM
Welcome to the forum, Dave!
Check for spider or maud dauber nests inside the burner tube:
https://www.google.com/search?q=wate...com&gws_rd=ssl
These nests can be small and tough to get out. You can usually remove the tube, blow with compressed air, and ream it out carefully with a small bottle brush, or a cotton hanky rolled up small so it will fit inside the tube. Shoot some compressed air inside the flue/tube which goes inside the heater body while you're at it.
You may have to adjust the burner tube location slighty to get a pure blue flame.
Good luck,
Peter
PS -- Did not watch video . . . keep as much distance from Goo as possible. :blink:
