-   -   Wanted: a turbo for a 1981 6BD1A Isuzu engine (out of my 1983 Airstream 310 (https://www.airforums.com/forums/f311/wanted-a-turbo-for-a-1981-6bd1a-isuzu-engine-out-of-my-1983-airstream-310-a-192454.html)
KB6YAF 02-21-2019 02:29 PM
Yes, the turbo on my 1981 Isuzu turbo diesel is leaking badly causing oil to be injected and thus creating a beautiful smoke screen.
The engine is the Isuzu 6BD1A....Year: 1981 in my 1983 Airstream 310 TurboDiesel.
I am going to attempt to remove it just as soon as the weather warms up a bit here in Olympia, WA.
Any leads on how to do this and if I can get a rebuilt, or new turbo for this beast would be greatly appreciated.
Russell Decker
92landyacht 02-21-2019 03:20 PM
Should be plenty out there rebuilt. I believe you need a turbo from a 1981 6BD1T engine. I think the Isuzu NPR of that era had it.
Isuzusweet 02-21-2019 05:12 PM
The person you need to PM, (he's in his 1985 325 turbo diesel in Arizona right now) is Shepherd57. John had to replace his turbo entirely and I'm not sure which Garret model he used, (Garrett 7?). I do know the compressor housing has to be rotated for it to fit, and he had to slightly grind something for clearance.
https://www.airforums.com/forums/memb...d57-48957.html
Good luck
Sidekick Tony
Smartstream 02-21-2019 07:05 PM
I have a Garrett number in my records but I don't remember the source. It is a Garrett, # 409080-9012. The original unit was supplied by BAE and they are still in business.
BAE Turbo Systems Inc.
Manufacturing Division
2275 Huntington Drive Suite 421
San Marino, California 91108
United States of America
(626) 576-7778 Phone
(626) 289-5576
e-mail: baeturbosystems@yahoo.com
Just remember it is a low pressure turbo because it is a naturally aspirated engine and doesn't have oil spray under piston coolers and other modifications that a true turbo engine has.
Mento05 02-22-2019 09:09 AM
Diesel Powerhouse rebuilds turbos. 9048797440
CALLAHAN FL
KB6YAF 04-10-2019 10:33 AM
UPDATE on the turbo for my 310....
Hi everybody....
I just wanted to throw out a hearty THANK YOU for those responding to this thread. I value the expertise that many of you have on these beautiful motor homes.
Here was the problem I was experiencing.....SMOKE!!! Yes, I was blowing TONS of smoke mainly at low speeds. The smoke was oil burning. I did a bit of research and found out that the probable cause was a bad turbocharger. I did spend a little money to have a professional mechanic verify my suspicions when I was in Arizona. Now, the problem was....Where in the world do I get a new turbo? Or, if the turbo could be replaced. The Isuzu dealer in Tucson said that they could get a new turbo, but the cost would be $5,700 just for the part, not the labor. Well, after I picked myself off of the ground, I told them 'thanks, but no thanks'. I would just get it back home to Olympia, WA and do the work myself. (no, I have never dealt with a turbo before!). Well, with all the burning oil and dripping oil due to very bad seals inside the turbo, I used a little over 4 gallons of oil to keep the levels up. Even though the oil was blowing out of the turbo, I was still getting 12 MPG!
When I got the motorhome home to Olympia, I did a bit of research and found a company called "Turbo Technology, Inc" in Tacoma, WA. With the help of a friend who is a professional mechanic, we removed the turbo from my Airstream motorhome. I took it to Tacoma to be rebuilt. They did indeed rebuild it with a brand new internal 'cartridge' all for under $800. (a far cry from $5,700!!!!) I brought it back home and installed the turbo myself.....VOILÁ....it works. NO smoke!!! The old turbo cartridge was so bad, you could wiggle the vanes about a 1/4" side to side!!! Yes, YIKES.
But.....I still had a leak. With a little help, it was determined that one of the two tranny lines going to the radiator was leaking. I went down to my local parts store and bought a 4 foot piece of steel line - 3/8" OD with the 5/8" nuts on the ends. Bend here, bend there, and it fit! No need for cutting and re-flaring.
After checking all the fluid levels, no leaks, no smoke. Yes, I did perform a total oil change, as suggested by the turbo people. Now my Airstream 310 Turbo Diesel is ready for its next adventure.
So, if you are in the same situation, those Garrett AR Turbos CAN be rebuilt. My hats off to Turbo Technology, Inc. out of Tacoma, WA. They are awesome.
Russell Decker, Olympia, WA
bkahler 04-10-2019 11:02 AM
Russell, there's nothing better than reading a success story :)
Congrats!
mayco 04-10-2019 05:53 PM
Right on!!!! Good research and good work!
