-   -   2018 Lounge EXT OEM Subwoofer (https://www.airforums.com/forums/f240/2018-lounge-ext-oem-subwoofer-191413.html)
gpern83 01-22-2019 04:42 PM
Hello,
I have a 2018 EXT Lounge. Under the rear passenger side, side facing seat is a small subwoofer. i have not read any mention of this on these forums. Is that standard equipment? Mine has issues. The sound is awful, and when I tap on the top screen, it makes a very harsh noise.
How do I get this thing out of there for inspection? The top grill does not have any screws going through it. Do I need to use a pick or something to pull the grill off?
Any information at all, related to this sub is greatly appreciated. Thanks in advance.
swilly43 01-22-2019 05:30 PM
I have a 2016 that has this subwoofer. I believe you can access from the vertical panel below the seat. I do not have access to the coach to confirm but I removed this panel to install the LP tank valve shut off and remember seeing the sub woofer. Mine works fine with no sound anomalies
TN Princess 01-22-2019 06:46 PM
Originally Posted by gpern83 (Post 2202336)
Hello,
You need to remove the passenger side jump seat, 4 bolts/screws. Remove the whole seat, not just the bottom. Then remove the wood platform the seat was affixed. Then you will see the sub-woofer. There is one screw in the cup holder slot.
If you just need to adjust or look, as the above post says, remove the panel in back of the hinged door on the passenger jump seat.
TX-Newbie 01-22-2019 08:18 PM
GPERN83. This unit is a powered sub enclosed in a box. This means it has an amplifier as a component of the whole unit. If it sounds bad the sub could be blown. The quality of the cone iis not the greatest It takes some tweaking on the EQ to make it sound better and carry the right frequency. Let us know what you find after removal.
gpern83 01-23-2019 10:54 AM
Thanks everyone. I'll dig into it this evening and see what I can find.
Moereece 07-21-2019 02:28 PM
I changed mine out with a 8 inch kicker .
Pahaska 07-21-2019 03:10 PM
I removed my 2018 sub-woofer when I converted to twin beds. It is sitting here in my office. I offered it on EBay with no takers. It had no issues, but would have taken up storage space in the rear that I didn't want to give up.
Anyone who wants it can have it for the cost of shipping + $10 for my time packing it and taking it to UPS.
We never listen to the radio except when driving. I can't tell any difference in the cab before or after removing the sub-woofer, so I just left it out.
gpern83 07-22-2019 08:13 AM
Did you swap out just the driver, or the entire enclosure? Was it worth the effort?
Pahaska 07-22-2019 08:30 AM
It is a self-contained plywood box covered in black cloth with a built-in amplifier. It was sitting on the wheel well, under the CS jump seat and was held in place by screws through two small angle brackets. I cut and taped the 12V leads and unplugged the audio jacks. Took about 2 minutes to remove the whole thing.
If anyone wants it, it is heavy to ship, but it is in pristine condition. If there is no taker, I may hang it under my desk and hook it to my computer to augment my Bose speakers.
Moereece 07-23-2019 08:45 AM
I just swapped out the sub and it sounds good.
