Sway bar for Basecamp X
I recently purchased a 2019 Basecamp X. I am considering adding a sway bar, so I am interested in your opinions and experiences on whether it would be helpful, needed, not required, or ...
Thank you in advance for response. |
Hi sswanson15. Any particular reason you're looking to add a sway bar?
Or are you talking about an anti-sway hitch? |
Welcome Aboard!! 🥂👍
Yes...do it. Light, single axle...the BCamp will benefit.👍
Bob 🇺🇸 |
Ah. Nomenclature difference.
You're looking for an anti-sway hitch, without WD. An anti-sway bar typically refers to a component that is fitted to car axles which help it from rolling/leaning in corners. |
Andersen Hitch
This hitch is a lite weight anti-sway hitch with load distribution. It works really well with an Airstream Base Camp.
He did post in Running gear, axles, wheels....and not in hitches?
get an easy-lift WD and sway bar
i would not us an As and a TV without both |
Unless towing with a Fiat 500, is this a concern with such a short and lightweight trailer?
There is no WD hitch available for Basecamp trailers. Sway bay only. There is no place to install snap up brackets, as the trailer is manufactured. |
And why in the world are people still insisting on recommending these, after thread upon thread about damage caused to Airstream couplers by them? https://www.airforums.com/forums/f238...wd-116908.html https://www.airforums.com/forums/f464...er-129761.html https://www.airforums.com/forums/f238...er-131162.html |
Anti-sway bar. You'll never need one until you do.
My neighbor has a Basecamp & a car trailer. He uses his Andersen on both trailers. He told me, the Andersen works well. |
Quick tongue weight poll for FC25FB loaded https://www.airforums.com/forums/show....php?p=2025010 |
Just a quick note that the Equalizer is a good option giving you both load distribution and sway control, it is mountable on the Basecamp.
Nice Flatingair. Definitely looks to be compatible with WD bars.
I think the Anderson would be an incredible pairing with the Basecamp-X. Because of it's lightweight and easy to setup nature. But more importantly, because of it's adjustable WD/sway control feature. As a Basecamp-X is suited for off-road use, being able to lesson the WD/sway tension is huge IMO. Something that many hitches including the one pictured there and my Equilizer cannot do on the fly. I've used Anderson and Equalizer hitches before. Again, I think the Anderson to be perfectly suited for this. |
