-   -   Type of Copper? (https://www.airforums.com/forums/f287/type-of-copper-191035.html)
Bubba L 01-10-2019 12:25 PM
Type of Copper?
We are to the point on the 55 where I need to start connecting the propane lines to the appliances as I install. I plan on using 1/2Ē main trunk line attached to the belly pan and branch off with 3/8Ē tubing and a valve to each appliance. Iím using double flares since I have the tool. I wanted to use soft K copper tubing due to the thicker wall over L. Iím having a tuff time finding a small quantity of K, so I may just go with L. Does anyone see a problem with short runs of L along the belly pan as long as I sleeve it with water hose or PEX? Or, does anyone know a good source for small quantities of soft K tubing? Thanks
AlinCal 01-10-2019 12:31 PM
Your fine with L soft. That's what airstream uses asfaik. K is overkill
A W Warn 01-10-2019 12:36 PM
Either K or L is ok for gas fuel. L is more appropriate for what you are doing. Read here>
https://www.copper.org/applications/...pecifying.html
Last pipe I replace I found it at Ace Hardware, cut to length at the store.
Bubba L 01-10-2019 03:54 PM
Thanks for the input. Thatís exactly what I was looking for. One problem solved and time to move on to the next, HVAC ducting in a 55.
