-   -   Engine oil (https://www.airforums.com/forums/f311/engine-oil-190114.html)
davejay 12-09-2018 07:34 AM
Engine oil
hey.
In my engine rebuild adventure, I've learned that the oil we have now, is not the same as the old days. My engine rebuilder says I must add a zinc additive or I will take out the cam. Am he added that the present day oils don't have most of the additives the old oil had. So every time I change oil , i must put a zinc additive in. You can buy this stuff at any parts store, but very few of these stores will have oil that has zińc and moly in the oil. My guy says Kendall racing oil is one that has it. We used to be able to buy diesel oil, like Rotella. But it also has been removed from these oils. Even oil such as Royal purple doesn't t have it. And I also found out that filters are different now. I used Fram forever. Turns out, that they have an internal flaw. They can collapse. recommended filters are Mobil 1,K&N, purolator, so, oil changes just got a little more involved. DJ
TG Twinkie 12-09-2018 07:44 AM
Get a second opinion on the oil and filter.
I have used Fram filters for 50+ years. Never had a problem.
I have had multiple engines in different trucks with 300K miles. Rarely was there a need to add oil between changes.
cwf 12-09-2018 10:30 AM
If he offers a rebuild warranty, do as he requests. He should know where to get the additive. Keep receipts, copy and send to him =) I do Oil sampling which provides a proof of oil analysis and mileage.
davejay 12-09-2018 01:48 PM
Hey,
I totally agree with you, regarding Fram filters. I've never had any trouble with them. But apparently, they have changed their mfging prossess.
If you find someone who will build you a 454 for 1800.00 bucks? Run away. My block got boiled, new cam bearings, new brass freeze plugs. Since this motor only has 5400 miles on it, I did not get it decked,line bored.
The crank needed to be ground. .010 on the mains, .030 on the rod mains. I did not have balanced or the rods turned.
The heads were in great shape. I ported and polished them. Guides were perfect, only a valve job was needed. No valves. New Comp cam and lifters,and edelbrock performer dual plane intake, new oil pump, and a single piece fel pro oil pan gasket. Hastings stock iron rings, and I'm all set to assemble it. Expect to pay a minimum of 3500.00 if your getting yours rebuilt .because this motor is so low mileage, and the damage was to the bearings, everything else was replaced because I had it apart. If I had 50k or more this engine, everything would have been done. The machine shop labor would have been 2500.
So please don't think you can get a rebuild on your engine for cheap. A good rebuild will run you at least 3500. That is if you remove and install engine yourself. Tack on another 1000 if someone does it for you. Your still getting off cheap at 4500. I'm so glad my dad taught me this stuff. Dads are great...DJ
GCinSC2 12-09-2018 03:12 PM
Does the rebuild include a new cam or the old cam?
Is there a difference in the metal used in old cam vs today’s cam?
Not an engine builder just my own repair center knuckle buster and bill payer.
Isuzusweet 12-09-2018 06:29 PM
I'm not going to get into an arguement about what oil filter is good and which are bad, but would like to add Wix, certain A/C Delco filters and Mann filters to your list.
IMHO, be very wary of oil filters that claim to remove particles down to sub microns, as these filters are fine for engines that are finely tuned modern engines running 0 weight oils. Older engines of the ilk that run our beasts could very easily plug up these micro fine filters, forcing the oil to bypass the filter very early in the filters life, allowing contaminates to circulate around your engine.
Cheers
Sidekick Tony
davejay 12-09-2018 06:54 PM
Hey,
I forgot about Wix filters. They are very good.
As for cams? If you go roller lifters that cam is harder. A flat tappet cam such as our older 454 s have will be softer. That is why it's imperative to have a very good lube with moly in it. 1st time start up, is where you can wipe out a lobe in very short order. I thought about a roller cam, but to much dinking around for the payback. You gotta get new pushrods. They suggest roller rockers, New valve covers, the plus is longevity . I'm not worried about that. This thing is never going to see 4000 rpm, so I'm not worried. DJ
CRH 12-09-2018 09:28 PM
Zinc has been reduced in oil, but not totally removed.
I use Rotella in my 460 and Jeep with flat tappers.
Been using Fram filters for over 30 years with no worries.
Magnet18 12-10-2018 07:10 AM
When building my 86 22re, there is much debate about zinc, but the general recommendation by the guys that built hundreds of them is use a break in oil with zinc, then switch to plain and simple dinosaur oil
I use either OEM or wix replacement for filters
Just my $.02
NHdigger 12-10-2018 08:10 AM
Check out oil for older engines sold by Hemmings Motors, pricey but may be what you need.
CRH 12-10-2018 01:14 PM
Just my $.02
I have a 22RE vehicle I bought new. It has gotten along fine on Pennzoil dino for 25 years.
bobmiller1 12-10-2018 05:15 PM
Just to add my .03 cents into the pot since it is stirring.....I use only Mobil 1 in everything I own plus factory filters.....no exceptions.......just my 3 cents worth.....had to one up you there. Regards, Bob
uraljohn 12-10-2018 05:35 PM
Engine Rebuild
I am an old school drag racer. I used to do rebuilds on all my cars that I raced. Way easier and less expensive in the long haul is to just contact Jasper Engines and order a Remanufactured engine from them. Great company, warranty and reputation. They even have a program to Reman your engine if you want to have a numbers matching engine. Tell them what you are looking to achieve and they will be happy to help. I have used them 3 times with success. Easy, easy, easy.
Magnet18 12-11-2018 05:31 AM
Congrats, you 0.01-upped me :lol:
Isuzusweet 12-14-2018 05:23 PM
FYI
Cheers
Sidekick Tony
https://www.youtube.com/watch?v=iTNJ...&frags=pl%2Cwn
dadstoy 12-14-2018 06:32 PM
Originally Posted by Isuzusweet (Post 2190133)
Awesome video! I’ve been buying WIX filters from RockAuto for a long time.
davejay 12-14-2018 07:27 PM
Holy mackerel,
I got some brand new frames in the garage. Going in the garbage. That just about says it all. Thanks Tony.
