-   -   Dometic AC Drain Cup Kit? (https://www.airforums.com/forums/f427/dometic-ac-drain-cup-kit-189538.html)
pteck 11-20-2018 04:51 PM
It looks like there are two different Dometic A/C drain cup kits out there.
In contacting Dometic, they are saying the following part number is the correct "Airstream Drain Kit", part number 3107688.024
Attachment 328232
Versus the other generic Dometic kit that's more readily available - 3107688.016
Attachment 328233
From what I can tell in picture, the cups look identical, with the generic .016 kit coming with a gasket set. Which is necessary as I understand it, to give the cups sufficient clearance against the roof surface.
Does anyone for sure know if there's a difference in the cups themselves?
