-   -   Shower drain Replacement (https://www.airforums.com/forums/f446/shower-drain-replacement-189213.html)
Julie-Bob 11-09-2018 08:46 PM
My 2009 25’FB Classic shower drain has corroded and needs replacing. How does one get to the nut under the shower pan to loosen the nut??
GMFL 11-09-2018 09:11 PM
On mine there is an access plate in the belly pan that allows you to get to the p-trap and shower drain.
Julie-Bob 11-10-2018 02:11 PM
does the shower drain just unscrew from the drain pipe under the shower?? I have looked under the trailer and the pan covers the area under the shower. Has anyone removed this shower drain pipe??
KJRitchie 11-10-2018 03:55 PM
I have a 2008 Classic 25fb. If you remove the furnace duct and have small hands you can access the shower drain. Other wise you will need to remove the wall. I was able to get my hand in there with a small adjustable wrench to loosen mine to fix a leak.
Kelvin
Julie-Bob 11-10-2018 08:08 PM
Thanks. I will check it out.
