-   -   Patio Light Lens Removal Tip? (https://www.airforums.com/forums/f240/patio-light-lens-removal-tip-187497.html)
Tronadora 09-24-2018 01:09 PM
I know at least one of you replaced your patio light... does anyone know how to remove this cover or lens without scratching the paint?
I've already tried inserting a thin jewelers screwdriver into various places to carefully find the right method but no luck. I just need the lens off so i can line the inside with a warming colored gel sheet. (I will also mask the top 2/3 with black tape so I don't light up the neighbors campsites, I had done this on the outside with good success and now will tape on the inside.)
Mark
Delores 09-27-2018 09:40 PM
Im tuning in also because I just noticed water has collected in mind. Hope someone knows the answer.
rmkrum 09-27-2018 10:18 PM
If it has a plastic lens, if all else fails drill a 1/16 drain hole at the lowest point of the lens.
