-   -   2006 Safari FB lounge (https://www.airforums.com/forums/f39/2006-safari-fb-lounge-187142.html)
TDF 09-16-2018 07:46 PM
What type of wood or plywood is under the upholstery of the bottom compartments and other areas? Im wondering if we should reupholster or just stain and seal?
DaveMc 09-16-2018 08:51 PM
Our 05 Safari has plywood thats +/- 1/2 thick. Id imagine it was built knowing that upholstery would hide blemishes in the wood and from assembly. Similar to the way the original mouse fur on the walls hides freehand cuts and imprecise riveting. All that said, I did not look that close at it since we knew we were using new Ultraleather on the whole dinette during our renovation.
TDF 09-17-2018 05:54 AM
Cost
Did you have someone local do the reupholstery? What was the approximate cost to do it in ultra leather? Thank you
