Best Trailer Hitch Lock for Class V, 2.5 inch ?
I'm looking for a high security, dependable lock for my hitch ball mount. Price is not a major factor.
I have a 2.5 inch, Class V hitch on my RAM 3/4 ton and would like a locking hitch pin that is corrosion and theft resistant. What have you found that fits the bill? |
I would recommend the BOLT 5/8" Receiver Lock. You can get one that can be keyed alike (by you) to your RAM ignition key. BOLT also makes padlocks and cable locks that can by keyed to your ignition key.
I have one... |
I just drilled out the hole a little bigger and use a padlock instead of a clip.
BOLT Receiver Lock
You’re looking for one that says “RAM 2500” - it doesn’t. Just look under the Dodge Pickup section. They use the same key type for all of the trucks and some Jeeps; and it’s be right size too. Hitch locks are weight rated, so you won’t necessarily see one that says “Class V”, but instead 2.5” receiver compatibility |
I was talking about my receiver pin. |
Originally Posted by CRH "I just drilled out the hole a little bigger and use a padlock instead of a clip." Quote:
No.....I drilled the existing hole in the 3 buck hitch pin out a little larger so I could put a padlock in the hole to secure the pin instead of a wire clip.
I was not talking about the coupler lock..... |
Attachment 317832 |
Gotcha.....My concern wasn't so much for theft than it was the fear of someone pulling out the clip as a "joke". I have three tow vehicles. I didnt want to spend 100 bucks on locking pins....If theft by were my top concern, I may have upgraded padlocks from the 2 buck flea market variety to a name brand....lol
I wanted one made in the US and very strong. After all, it's keeping your entire rig attached.
So after a lot of research I found this one: C.T.Johnson (RH5-XL) 5/8" Hitch Lock https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The Tundra has a very stout receiver and the 2" one doesn't fit, so I added a couple of rubber hose washers to take up the slack (5/8"!) |
BTW, if you watch the YouTube videos, any pin lock will leave you depressed. A determined thief takes a piece of pipe about the size of your lock cylinder, slips it over, bends the lock and it snaps like a twig! Two seconds and he's got your hitch.
As always, it keeps the "opportunist" away. Usually, that's enough. |
Proven Industries Model 2516-AS
Connor from amazon
