-   Airstream Classifieds (https://www.airforums.com/forums/f534/)
-   -   Custom Folding Dinette Table (https://www.airforums.com/forums/f534/custom-folding-dinette-table-183729.html)
RFP 07-02-2018 04:36 PM
Title:
I just posted a new ad on Airstream Classifieds.
Custom made folding table specifically for late model 16', 19' and 23D. Overall size: Folded - 29 5/16" X 20". Fully extended - 29 5/16" X 38 1/2"
Made from high quality 18mm Baltic birch and white ash and laminated with premium Wilsonart "River Gemstone" laminate. This table will outlast your present Airstream and the one that replaces it. The hinges are secured to solid ash (no screws into plywood edge) which is half-lap joined to the Baltic birch plywood.
The table gives you the convenience (and extra room) of a small "morning coffee/afternoon tea" size when you want, or a full-size dining table for meals.
The table installs with the original factory hardware. You only need remove the two metal 'brackets' on your factory table top and install the brackets on this table top. It will fold down to the usual make-a-bed position if you wish.
The table may also be used on other Airstream models, but the overall width is some 6" narrower than the factory tables on 8 1/2' wide trailers.
This is an excellent table, produced in my own shop. I am proud to offer a folding dinette table that meets or exceeds the expectations of Airstream owners.
Local pick up would be preferred. Shipping would likely be expensive... the table is no lightweight and it would be a fairly large package.
You can contact us by filling in the form on the right hand column of the ad listing:
https://www.airstreamclassifieds.com/...dinette-table/
