-   -   Gasket? Weatherstripping or...'65 Safari window leaks! (https://www.airforums.com/forums/f456/gasket-weatherstripping-or-65-safari-window-leaks-183167.html)
DeniseP 06-19-2018 09:31 PM
hi!
I am the recent owner of a 1965 Safari I am completely in love with.
Two windows have rotted seals between the glass and metal window frames.
Are there specific materials I can buy to clean off the old (or just scrape?) and more importantly replace the old with so the rain stays out?
The gray rubbery sealant seems like it would come in strips and be self adhesive or heat sealed on there. Can anyone point me in the right direction to make the repairs?
Thank you!
Denise
Bubba L 06-20-2018 06:22 AM
Denise, I would check Vintage Trailer Supply to match up your old gasket with what they show for the mid 60s windows. With gaskets we’ve installed, we always use 3M Black Super Weatherstrip And Gasket Adhesive from auto parts stores. Clean the gasket remnants off the glass with something like GoofOff and a razor scraper. Good luck, Bubba
68 TWind 06-20-2018 08:34 AM
Once you remove most of the old gray seal use a Dremel tool with a Scotch-brite "bob" to clean the rest of the junk and get to surface clean so the new gaskets will stick. It is the best and fastest way I found to clean the old glue and other residue and not scratch the aluminum ( I had to do all 6 windows in my Trade Wind). They take a special mandrel that holds the Scotch brit pads, sold separately of course. Lowe's had HD has them.
