-   -   Overhead cabinet hinge screws pulled out (https://www.airforums.com/forums/f38/overhead-cabinet-hinge-screws-pulled-out-182397.html)
Fipp 06-02-2018 01:14 PM
The overhead cabinet door in the galley area of our 2016 25' flying cloud has the three screws pulled out of the spring loaded hinge. These are the screws on the curved part door that swings down to shut it.
The holes are too big now and the screws won't "bite". There is so much pressure on these when opening and closing that I'm wondering how to secure the screws back in well enough.
Toothpicks,matchsticks and wood glue seem like it won't be enough.
Anyone had this issue with a successful solution?
billrector 06-02-2018 01:25 PM
I had the same issue with my 27' FC. Mine was not so stripped that the screw would not go in and stay by itself, but I could not tighten it. I used some epoxy (and might have used a wood toothpick) to get it to hold. So far, it has not loosened.
Wayne&Sam 06-02-2018 01:31 PM
Toothpicks and glue should work. Might try a wood filler and then re-drill a pilot hole. I'd also think about backing off on the spring pressure on the hinge.
