-   -   Power stabilizer jacks (https://www.airforums.com/forums/f540/power-stabilizer-jacks-182027.html)
DeltaRon 05-24-2018 07:17 PM
On 2018 Classic with power stabilizer jacks. How do you operate manually when power doesnít work? No mention in manual.
Al and Missy 05-24-2018 07:38 PM
You should have a long crank handle with a pin in the end. You stick it in the hole in the end panel and feel around until it engages, and then crank. If you don't have the crank, somehow I ended up with extras. Let me know and I'll bring you one to Alumalina.
Al
DeltaRon 05-24-2018 08:15 PM
Al
Thanks. Iíll take a closer look.
Overstreet 05-25-2018 04:20 PM
I'm getting confused but I think mine was in the closet. I keep getting the picture of my trade in's handle on the wall of the pass through storage. Perhaps look in the trunk.
uncle_bob 05-25-2018 08:24 PM
Hi
Another popular "backup" is to rig an battery / electric drill to fit the hex head "bolt" on the jack. That way you don't crank your arm off :)
paiceman 05-26-2018 08:12 AM
I received the long handle and a short snap in adapter for my 1/4" electric drill. The adapter fits perfectly on the road side stabilizer and I can raise or lower using my electric drill. Check the packet your emergency awning closure pieces came in as that is where mine was.
