-   1961 - 1963 Bambi (https://www.airforums.com/forums/f16/)
-   -   62 bambi floor dimensions (https://www.airforums.com/forums/f16/62-bambi-floor-dimensions-180668.html)
pryner 04-24-2018 06:35 PM
I finally removed the shell from the frame and got the floor and belly skin off. Unfortunately the floor is so rotten in the rear I can't tell what the radius and dimension the floor should be. The C channel was barely attached to the floor and was mostly attached to nothing in the corners as the wood was gone. I can get a good idea from the shell but if someone has any measurements it would be appreciated. BTW it was a good thing I tore all down to the frame. One cross member was completely missing along with one longitudinal piece and two other cross members have severe rust holes. Off to the welder then blasting and power coat. TIA for any info
