-   -   Automatic step magnetic sensor placement (https://www.airforums.com/forums/f311/automatic-step-magnetic-sensor-placement-178476.html)
realpank 03-04-2018 10:23 AM
My magnetic sensor for my Kwikee auto-step bracket has broken.
It is located on the latch side about 1/3rd of the way up from the bottom.
I recon this location is not optimal there is easy access for it to be hit as you enter the RV.
Question?: any recommendations on a different mounting location out of harms way and still function properly?
Thanks in advance for replies.
Chris
chriscraw 03-05-2018 02:59 PM
Step switch sensor
Here are a couple of pics of my step switch install which works well despite a badly fitting screen door. Hope this helps.
realpank 03-06-2018 09:33 PM
Thanks Chris
What I was hoping to see.
I'm hopefull that being more aware it might not get whacked next time in the same location
