https://www.suremarineservice.com/s.n...gory.318481/.f
Try this link above. I used a vitrifrigo conversion kit. Works great. No freezer with a flat plate evaporator, but they do offer a "boxed" evaporator that should fit in the freezer. My propane system still works somewhat, when it is very hot outside or want to cool down quickly I run both the propane and 12V compressor at the same time. I'll send some photos in a bit. |
See photos attached:
(1) Outside of M50 fridge, (2)inside of fridge showing evaporator plate on back wall (looks like I need to defrost it!), coolant plumbing and thermostat and 1" hole I drilled in the bottom, (3) photo underneath the fridge showing compressor install (a little dark) |
the end of that thermocouple looks like a normal one you see at lowes or homedepot in the water heater section.. only difference is the thread is course as most are fine thread I find. we have a convertor that adapts the threads. so of them are are US threads and some are European threads.
